It is currently Fri Nov 06, 2026 5:22 am
Post Posted: Thu Jan 31, 2013 3:27 pm
Q> Will a "immobilised" ECU (2002) swap out with a "non immobilised ECU" (1998) in J20 GV's ?
i.e. is it Plug ang Play from 2002 to 1998 model, or does the entire harness need swapping over, incluiding the immobiliser bits, antenna, transponder key, BCM,etc.....
Post Posted: Thu Jan 31, 2013 3:54 pm
I would assume that they are NOT interchangable.
Perhaps losfer or fordem will know for sure.
Post Posted: Thu Jan 31, 2013 5:10 pm
Thought so. Even if the immobiliser crypto is in the bcm it still needs to send the signal to the ecu to allow it to start the car.
Post Posted: Thu Jan 31, 2013 5:43 pm
Yep. Same with the current M series swift stuff. Everything is integrated into BCM and ECU looms.
Post Posted: Thu Jan 31, 2013 10:00 pm
As far as I know you only have to swap over a couple of wires in the ECU plug but you will need to source an ECU with, matching immo and key. I would imagine the looms have provision for the immo but maybe not for the transponder. Is the BCM matched to the immo? I wouldn't have thought so.
Post Posted: Fri Feb 01, 2013 5:58 am
To clarify, I have a customer who is desperate for the ECU, however his car is a 1998 model, whilst the one I am wrecking is a 2002 model, so i don't want to sell him the ECU if he can't use it...
Post Posted: Fri Feb 01, 2013 7:21 am
In that case no it doesn't fit.
Vehicle: 4wd
Post Posted: Fri Feb 01, 2013 7:32 am
I think you'd be better off keeping the motor, ecu, and loom as a package.
Watch out or you'll get sued.
Post Posted: Fri Feb 01, 2013 8:21 am
Makes sense.....I have a LWB J20 as well, so might keep the motor as a spare, and sell the ecu/key/bcm/antenna/harness complete, which will get the J20 running if someone is doing the conversion........
Vehicle: 2002 Suzuki XL7
Post Posted: Fri Feb 01, 2013 10:58 am
Good to see Rhinoman monitoring these forums :) Mention ECU and hes right on it :lol:
I tried reading a 1998 model ECU and i came to the conclusion they are different languages, as the Suzuki Scan tool would not connect, but a 2002 model it will. A Transponder Key Id usually has to be programed into both the Imob and ECU where both accept the code before starting the car..
Post Posted: Fri Feb 01, 2013 6:03 pm
1998 uses the early SDL protocol supported by the Tech2, 2002 Aus model uses SDLKWP as determined by GeckoXL7. The immo has to be matched to the ECU and the key to the immo. Suzuki swap a couple of wires over so if you plug a non-immo ECU into an immo vehicle it won't start. If you were desperate to get the 2002 into the 1998 then it could be done but you couldn't sell it as a straight replacement.
Users browsing this forum: No registered users and 86 guests
