Joined: Mon Jul 30, 2012 8:49 pm Posts: 518 Location: Canberra ACT
Vehicle: Lwb vit, 31's big white fridge
Posted: Sun Feb 03, 2013 2:15 pm
Help!! Wheel came off today on the way to the 4wd tracks
Got it back on and tow trucked home Threads on the axle are stuffed.
I need new brakes- drum- axle studs and wheel studs/nuts Possibly new axle housing as the Lower shock mount is bent inwards quite badly compared to the other side. How can i tell if the axle housing is bent?
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
Posted: Sun Feb 03, 2013 11:08 pm
that sucks, measure to a fixed point somewhere along the chassis on both sides. do it in a few directions to, if your numbers dont add up to be the same then its bent.
Users browsing this forum: No registered users and 176 guests
