It is currently Thu Nov 05, 2026 4:15 am
Post Posted: Fri Apr 05, 2013 8:04 pm
hi AZ,
Does anyone see any problems with running one of these fused battery terminals with an 100Amp ANL fuse instead of a fusible link on my sierra? My plane is to run a suitable sized wire from the 110amp falcon alternator straight into this terminal on the battery. Then I'll run the factory yellow/white wire into one of the auxiliary fusses in the terminal aswell.
I was thinking this would make things a little neater with the wiring but if you guys don't think it's worth it I could just get the an auto spraky to make me a new fusible link to suit the 110A alternator.
http://www.ebay.com.au/itm/281075545296 ... 1423.l2649
thanks :D
Post Posted: Fri Apr 05, 2013 8:13 pm
I would do it, not that terminal though cause there is nowhere for the starter cable to go
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Apr 05, 2013 8:17 pm
Looks more like a terminal for the second battery. I am not sure what the starter current is for a Suzuki but quite possibly up near 100 amps. I agree with Royce. I like the look of the terminal set up but no where to connect a winch or starter cable, that is why I think it is not meant for the main battery.
Post Posted: Fri Apr 05, 2013 8:24 pm
ahh you guys are right, I completely forgot about the starter wire :oops: haha. Does anyone know of any fused terminals that would work? I can't seem to find any others online. I suppose if I can't find a suitable terminal I could just put a 100amp fuse in a fuse holder?
thanks guys.
Vehicle: 2018 DMAX
Post Posted: Fri Apr 05, 2013 8:41 pm
Can you run a circuit breaker? There are some high amp multi outlet breakers out there, either auto resetting or manual. Remote mount it with some 0 gauge.
Post Posted: Sat Apr 06, 2013 7:01 am
I know a site has what you want but its down right now
have a look around a wreckers at some late model stuff, I reckon you'll find something to suit you
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sat Apr 06, 2013 7:54 am
it claims you can run a starter off the 8mm post
"CAL2 Fuse Technology
Allows the load of a starter motor or winch to operate without blowing the fuse, but is still sensitive enough to blow in the case of a direct short. 150A continuous/800A peak fuse. "
for $40 id give it a try
Post Posted: Sun Apr 07, 2013 4:43 pm
cheers I might have a look at the wreckers for something suitable :)
Users browsing this forum: Google [Bot] and 555 guests
