It is currently Wed Nov 04, 2026 7:37 pm
Post Posted: Sun Apr 14, 2013 8:26 am
My mates G16B in his Vitara has the std crack in the block above the starter motor he also has a G16B single point inj motor out of a swift sedan in his shed.
What we want to know is can we swap all the manifolds cam dizzy and sump over to run the swift motor in his vit?
Also do the swift G16B's suffer from cracked blocks or is it just the Vitara's?
 Profile YIM
Post Posted: Sun Apr 14, 2013 9:04 am
If the Swift 16B is a 16V then everything will swap.
AFAIK there are no differences in any of the 16B blocks that say one will crack and one won't.
Post Posted: Sun Apr 14, 2013 11:31 am
Are the heads the same will all the Vitara bits fit the swift?
 Profile YIM
Post Posted: Sun Apr 14, 2013 4:46 pm
My import engine was a G16A from a Swift 4wd, but was efi 16V.
Everything swapped over ok.
I used Vitara cam, dizzy, sump, oil pick up, and bearing cradle.
And all the external bolt on bits.
Post Posted: Mon Apr 15, 2013 11:38 am
cheers so should work ok then Armsup
 Profile YIM
Users browsing this forum: No registered users and 178 guests
