It is currently Wed Nov 04, 2026 9:11 am
Vehicle: 89 Suzuki sierra
Post Posted: Sat May 11, 2013 10:20 pm
have a problem with my zook,
all my indicator globes work, they are all the right watts/volts.
left side flashes normal, hazards flash normal BUT right side flashes fast.
no idea what is happening or where to look anymore, checked the connections and swapped globes over to other side
and nothing has changed.
any suggestions ?
Post Posted: Sun May 12, 2013 8:08 am
Replace flasher relay.
Post Posted: Sun May 12, 2013 8:22 am
dont all the indicators run on the one relay?
Vehicle: 82 Sierra SWB soft top
Post Posted: Sun May 12, 2013 10:00 am
Are they led or standard jobs? Does the light on the dash come on when indicating to the right, I found mine when nuts when a had the dash out. Most of mine are led but it seems the light in the dash was enough to bring the flashing to a decent speed.
Post Posted: Sun May 12, 2013 10:01 am
I'd be looking for a bad earth in the right indicators.
Post Posted: Sun May 12, 2013 10:05 am
flasher units speed up when there isnt enough current through them, a high resistance circuit would lower the current enough to make it think a bulb is out.
I would look at all the bulb housings on that side, give them a clean and lube, look at all the connections etc
Post Posted: Sun May 12, 2013 10:06 am
Bad earth or incorrect watt globe
Post Posted: Sun May 12, 2013 8:24 pm
hey guys thanks for the reply's, all my globes are standard, not led and the globes in the dash do work. i will have another look after work tomorrow for bad earths and check the globe sockets.
will keep you all updated on what i find.
cheers
Vehicle: Jimny '09 Manual
Post Posted: Mon May 13, 2013 8:07 pm
Swap them all to the other side and see if it happens. Sometimes a globe thats about to blow can do funny things like that before it dies,
Vehicle: 98 Coily
Post Posted: Mon May 13, 2013 11:04 pm
He already swapped em over and got the same results so its probably not the globes.
Users browsing this forum: Google [Bot] and 609 guests
