It is currently Wed Nov 04, 2026 11:26 am
Post Posted: Mon May 13, 2013 8:03 pm
What oil filter is everyone using.
The Ryco No for the H25A V6 is Z172 and the J20 4cly is a Z418.
Is it ok to use the Z418 filter on a V6? They have the same size thread, same diameter but the Z172 is about 20mm longer.
I ask as its sometimes hard to get the Z172 off the shelf at some places and the difference in price is quite alot.
Post Posted: Mon May 13, 2013 9:44 pm
I'd imagine that the Z172, being larger, would have a higher flow rate....could be wrong though
Post Posted: Mon May 13, 2013 10:27 pm
depending on how much long it is, you would get better filter life because of the surface area of the the filter is greater, blockages occur less.
Post Posted: Tue May 14, 2013 5:06 pm
The difference in length is less than 20mm. I plan to start doing oil changes every 5000kms.
Doubt it will cause any problems with short changes.
Users browsing this forum: No registered users and 103 guests
