It is currently Wed Nov 04, 2026 9:59 am
Post Posted: Fri May 17, 2013 7:47 pm
Hey guys, been doing some looking around on here, researching what shocks to put in the rear of my vitara, vp and vn seem to be the ones to suit 2inch spring lift, so I bought some Gabriel guardians. Put one in and jacked the vit up and down to see how much flex I would get, but before the shock got to its full extension the spring came loose buy about 50mm and the brake lines pulled tight, I couldn't find anyone that's on here that has used a spring retainer or extended brake lines with this setup. Please help
Cheers smally1.6
Post Posted: Fri May 17, 2013 8:42 pm
Just stick spring spacers plus a Heim joint spacer in
Post Posted: Fri May 17, 2013 11:13 pm
but look at longer brake lines - you dont want to be using them as limiting straps! =)
Post Posted: Sat May 18, 2013 12:07 am
Unbolt brake and handbrake lines from the clips on the chassis, gives them more wiggle room.
Post Posted: Sat May 18, 2013 7:12 am
Are you're springs so short that they will fall out? Mine have always been loose but the don't fall out.
Post Posted: Sat May 18, 2013 4:16 pm
if they come loose they are to short
im looking for around 550 long coils for mine
Post Posted: Sun May 19, 2013 1:51 pm
My TD GV coils are 365mm free - 550 would be hoooooge, they'd have to be beyond Calmini soft and be binding almost at ride height...?
Post Posted: Mon May 20, 2013 4:07 am
im aiming for 4 in lift and i have 3 in bumpstop spacers
something dual rate would be good
Users browsing this forum: Google [Bot] and 95 guests
