It is currently Thu Oct 22, 2026 4:15 am
Vehicle: 75 Cruiser
Post Posted: Sat Jul 25, 2009 8:05 pm
It seems all the big welders are 15amp so i'd have to get a 15 amp point installed and that sounds too hard. These welders cost from $1200 up to $3000.
The smaller 10amp ones seem to be gas/gasless.
Do the 10amp gas/gasless ones do welds as good as the bigger 15amp ones when using gas ?
I currently have a gasless and the welds look ok most of the time, but when using a nice big gas mig the welds look soo much better.
Post Posted: Sat Jul 25, 2009 8:56 pm
gasless is a waste. i recently put my mig on gas. i never used gasless on it as i would use other methods of welding. i had the bopttle of argoshield so i though may as well try it.
my welder is a unimig panther 172. 15amp plug ground down (though i do have 15amps now) i have ran it at max setting and never had a problem.
navara on 33s. hopfully rear air locker soon
Vehicle: 75 Cruiser
Post Posted: Sat Jul 25, 2009 9:23 pm
Thanks Brendan, i did a search on the Panther... So it's a gas/gasless and sell for around $900.
I looked at a Cigweld Transmig 165 which sells for around the same price. It's also gas/gasless.
I was just worried that it may not be any better than what i have now. But if you think yours welds nicely using gas, i would assume the transmig should be of similar quality.
Post Posted: Sat Jul 25, 2009 9:36 pm
Hi Steve
Genereally speaking, the larger machines have 15A plugs because they have larger internal transofmers. These give longer duty cycles and more consistant welds. You CAN run a 15A machine on 10A supply, but it really restricts the power supply and can reduce your duty cycle and welding amps.
As you know my machine is a 255 single phase lincoln. I have been running it on a dedictaed 20A supply for a while ( 2.5mm wire) and recently I have been doing some HEAVY welding. Consequently I have been tripping the 20A RCD on the board after half an hour or so of welding. I had a mate come and check it out, and at full power, the mig was drawing over 34A 8O So now I am having to run 6mm cable with 32A plug and RCD.
If you do buy a bigger machine, it would be worth the money to put the coirrect power supply in. Otherwise you will have nothing but problems in the future.
Post Posted: Sat Jul 25, 2009 9:48 pm
yeah what he said, probably not a lot of money to run a line from the fuse box to round the back of your place, or if you know somebody to the hard work yourself and get it checked by them
Post Posted: Sat Jul 25, 2009 10:08 pm
i have acelly got a 20amp powerpint in my shed. i run my welders and grinders off that. got 1 in the shed and 1 in the carport for when i need to weld on the car. installed myself
Post Posted: Sat Jul 25, 2009 10:09 pm
i have acelly got a 20amp powerpint in my shed. i run my welders/spazma cutter and grinders off that. got 1 in the shed and 1 in the carport for when i need to weld on the car. installed myself
Post Posted: Sun Jul 26, 2009 1:22 am
what are you trying to weld that you need a big duty cycle?
Post Posted: Sun Jul 26, 2009 4:40 pm
unless your you are in protuction duty cycle isnt realy somthing that need to be good. even if you got a 20% duty cycle at full amps thats still 2mins of welding time. unless you doing heavy plate vertical welding then its a bit over rated. but still good to have somthing that going to handle what you want to weld everday, you dont want a machine where you are cranking it at the max all day everyday
Users browsing this forum: Google [Bot] and 165 guests
