It is currently Tue Nov 03, 2026 8:09 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Jun 10, 2013 4:17 pm
Need some help locating the wires to the 4wd sw on my vit loom
The loom is from a 93 vit 1.6 and going into my LJ
I've search the wiring diagrams I have and it says its a orange/black wire from the ECM plug 18
Problem is no wire that color is in the plug and the plug does not look like the one in the wiring manual
Post Posted: Mon Jun 10, 2013 11:28 pm
Are you sure you're looking at the correct diagram? I don't think the 4WD switch connects to the ECU on the SE series Vitaras - I believe it's straight from the switch to the cluster.
Post Posted: Tue Jun 11, 2013 12:53 pm
no I am not sure but if you know the color of the wires to the switch and the plug let me know. The wiring diagrams I have are slightly different to the loom
Post Posted: Wed Jun 12, 2013 6:59 am
I believe orange/black is correct.
Vehicle: 95 Vitara Hardtop
Post Posted: Wed Jun 12, 2013 7:56 am
Gee if only I'd read this two days ago, just finished putting my gearbox back in, unfortunately I didn't take any notice of the colour of the wires, but might have been useful to check at the time....
Post Posted: Wed Jun 12, 2013 11:02 am
Problem is I cant find them coming out of the loom. I can trace them from the instrument cluster to the ECU and not out from the ECU
Post Posted: Thu Jun 13, 2013 11:08 am
On my Vit the plug is located under the rear end of the inlet manifold, and is quite difficult to see when installed, there is four wires to it, reverse switch and 4wd switch, so you might be looking for a four wire plug not two wire plug, (the loom them runs along the top of the gearbox). Unfortunately I didn't check where it went after it disappears into hoses and other parts of the wiring.
Post Posted: Thu Jun 13, 2013 5:14 pm
ok getting somewhere, I found the plug that goes to the reverse switch it has
four wires in - Y, Bl/O, Lg and P
four wires going out - LG,Y/B,P and Bl/O.
The only one not spoken for is the Y/bl out could this be it?
Post Posted: Thu Jun 13, 2013 11:16 pm
Put a meter on it - does it go to ground when you shift into 4WD?
Post Posted: Fri Jun 14, 2013 7:16 pm
Won't happen because its not connected to anything yet, remember this is a fit loom in an LJ with A sierra transfer
If I get time on the weekend I'll short it out and see if it turns the 4wd light on
Post Posted: Fri Jun 14, 2013 11:40 pm
Sounds like a good way to burn something out - why not connect a test lamp instead - if it does turn out to be the 4WD light connector, both the 4WD light and the test lamp will light.
Post Posted: Sat Jun 15, 2013 8:00 am
Just tried it with test lamp and not lights that YBl wire must be for something else -maybe aircon
Back to the drawing board
Post Posted: Sun Jun 23, 2013 5:18 pm
Well to close this off I found the wiring.
The switch loom was still on the transfer case(which I wasn't using)
So the plug is under the rear of the inlet manifold and depending on the model can have up to 5 wires which are for reverse, 4wd and Lo.
Users browsing this forum: Google [Bot] and 111 guests
