It is currently Tue Oct 20, 2026 3:09 pm
Vehicle: LWB Sierra & XL7
Post Posted: Sun Jul 26, 2009 4:55 pm
I'm just having a little trouble with the power windows in the Vitara. After pulling out the passanger side window motor, I found that the wire that pulls the window up and down was jammed in the spool preventing the window to go up or down. I pulled the wire out and ready to re-assemble, but here's where I got stuck.
I thought I'd check that the motor isn't stuffed before putting it back together, So I tested it on the driver's side connection and works fine, I recconect it to the passanger side and it strugles to move.
Seems like it isn't getting enough power to operate, but it works just fine.
Any ideas on why this is happeneing?
Vehicle: jimny
Post Posted: Sun Jul 26, 2009 5:14 pm
trace the wire back, probably a dirty connection further in. did you bypass the switch? isolate that and see if that fixes it. also try putting a multimeter on to it, i have one if you need to borrow one
Post Posted: Sun Jul 26, 2009 6:17 pm
sounds to me like your meck is stuffed!you sure it wasn't damaged when the wire got jammed in the spool?I would be checking the wire ect before you burn out the motor!
Coily GTI Turbo...thats right its a coily!!
Post Posted: Sun Jul 26, 2009 9:32 pm
I cleaned the plugs and connections while i had it off, So I don't think it's because of that. I've posted emails to a few suzuki wreckers to see how much a new one would be. What a cuntry of a job it is, I'm starting to think it would be easier to replace the whole door. :lol:
Post Posted: Mon Jul 27, 2009 1:14 am
when u checked it in passenger side was it mounted?
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Mon Jul 27, 2009 2:06 am
No not properly mounted. I've managed to prop it up with a bit of wire and cable tie's before it started raining. Might drop it off to the mechanics to sort out...
'92 Vitara & Camper trailer
Post Posted: Mon Jul 27, 2009 2:09 am
lube up the tracts and mount it prperly and give it another go
Post Posted: Mon Jul 27, 2009 3:49 pm
I can supply a new LH Front Regulator for $ 165.00 plus postage of $ 20.00
Patrick
Discount Suzi Spares
And from Suzifour
passanger side elec reg for 2 door car or a 4 door car
2 door reg elec $120.00 4 door $125.00
There's no difference to the 2 & 4 door is there?
Users browsing this forum: No registered users and 169 guests
