| Author |
Message |
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Wed Jul 10, 2013 9:48 pm |
Hey guys been having some problems with my suzuki sierra It has missfire underload about 40 kph then stalls iv change the head recently from a 16 valve set up to 8 also I had this problem with old head and Carby so I changed whole top end I'm starting to think its Bad fuel
Things i have changed Leads Plugs Dizzy Cleaned cap have not changed yet Also changed fuel filters and went from electic Pump to mechanical It also has weber Carby Igntion timing set at 10 * before tdc At 800rpm
The motor does not have best compression 90-100 And only had extractors so does not have back presure Ideas guys Cheers
TryHard
 Posted: Wed Jul 10, 2013 11:38 pm |
Might try reseal intake manifold and another coil although its fairly new
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Thu Jul 11, 2013 12:07 am |
Try starting it on a pitch black night n look under the bonnet, see if you have any lightning round the dizzy, could be a cracked cap.
TryHard
 Posted: Thu Jul 11, 2013 8:56 am |
Yep cheers il try that tonight
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Thu Jul 11, 2013 12:31 pm |
The ignition system doesn't know how fast you are going. What revs and load is the engine at when it fails? Does it break down at full or light throttle?
Did you rejet the carb? You have massively reduced airflow through the head if you've swapped from a 16v head to an 8v. Maybe it's just running rich and stumbling.
SuziBlu
 Posted: Thu Jul 11, 2013 12:38 pm |
It does know what revs and load it has, and at the speed OP taking, i would have thought heavy take off load.
Gwagensteve
 Posted: Thu Jul 11, 2013 1:40 pm |
I think you've misunderstood. The engine doesn't know how fast the car is moving. That's not relevant. Engine revs and load (throttle position) are relevant.
SuziBlu
 Posted: Thu Jul 11, 2013 3:15 pm |
Thats what I was meaning Steve, 40k and he is possibly in third or forth, hard throttle, speed means bugger all.
Most people try n keep up with "normal" cars in their lil suzis, so I suspect close to WOT.
Lot of pressure electronically at that gearing and throttle pozzy.
dtchch
Joined: Sun Jun 09, 2013 1:43 pm Posts: 35 Location: Christchurch, NZ
Vehicle: Vitara SV620
 Posted: Thu Jul 11, 2013 7:17 pm |
I've got a similar problem, only does it once hot misfires up to about 3000rpm then stops. Done all the ignition apart from the coil - starting to suspect fuel.
I'm going to get a fuel pressure/vacuum tester and check that - worth you doing the same. Dodgey fuel pressure due to pump or regulator can cause similiar issues
TryHard
 Posted: Thu Jul 11, 2013 7:29 pm |
Hey guys thanks for the replys to clear it up iv Had same problem with old head the Carby is a different one Since inlet manifold was different ATM I has weber It happens about 3 k rpm under load 3 gear The Carby float level had been adjusted but i do not think its Carby issue because As i have said before it done this before head change
That's why I'm thinking doggy fuel or igntion Might run tonight for stay sprak
