I drove my lwb to the blue slip shop, drove it home, left it for two days and now it won't start. The battery is 12.67V. There is fuel squirting out of the pump. I replaced all the plugs, leads, rotor cap, little spinny thing inside and the coil off my working zook and it still did the same thing. Is there something i should check or is it not sounding like an elec issue?
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
Posted: Sun Aug 02, 2009 9:47 pm
check for spark. you could have a problem with the wiring (window wipers as well) make sure your getting power at the coil and its hooked up the right way.
yeh i checked for a spark at the coil lead by touching it while cranking it over and got nothing... so im looking for loose earths at the moment. It's just odd that it works oneday and not the next...grr
Users browsing this forum: Google [Bot] and 227 guests
