It is currently Tue Nov 03, 2026 1:25 pm
Vehicle: Vitara 1990 SWB Soft Top
Post Posted: Wed Aug 28, 2013 8:48 am
OK ... Its got me Buggered... :?
I'm in the process of installing my new raised springs in my SWB VITARA Project. Rear Springs and Shocks not an issue and looking real FLASH :woohoo:
Front Springs doing my head in. I have a set of spring compresses but they won't compress far enough. I've undone sway bar etc but still not enough drop in the lower control arm. I don't particularly want to disconnect the CV's etc... What am i doing wrong? I was told that with the strut out and sway bar undone it should all drop enough to get the new springs in. My next step was to undo the lower control arm and see if that will drop it enough at the inner side.
Advice please... doing my head in. I know it should be a simple job... :rambo:
Thanks
Bretski
Vehicle: SJ80, SE416
Post Posted: Wed Aug 28, 2013 9:29 am
Undo the 3 bolts under the ball joint to allow the arm to drop further. The CV and steering will hold the hub up while you do this.
Post Posted: Wed Aug 28, 2013 9:50 am
I have to undo the brake line from the strut as well on mine.
I have lifted springs and spacers and it goes in without a spring compressor.
Post Posted: Wed Aug 28, 2013 9:54 am
I did consider this... I actually tried to undo the ball joint... but its stuck good and proper... Was getting too late to keep going...
I think I will try this... Thanks
Post Posted: Wed Aug 28, 2013 9:55 am
Brake lines already detached from rebuilding the brakes. Thanks anyway.
Post Posted: Wed Aug 28, 2013 4:49 pm
Try undoing the bolts holding the lower arm to the chassis. Don't remove the bolts just loosen them off a little. Helps the arm swing down.
Post Posted: Wed Aug 28, 2013 5:04 pm
Get someone to push the arm down as much as possible, 'screw' the spring up the bumpstop, line the spring up and give it a good kick. Should pop in then spin it till the spring seats properly.
Post Posted: Wed Aug 28, 2013 5:09 pm
this guy knows how to fit long springs Armsup
Post Posted: Wed Aug 28, 2013 5:12 pm
but don't forget to kick his fingers if they are in the way.
Post Posted: Wed Aug 28, 2013 8:55 pm
Ok All Done... thanks for the feedback guys. There was no way in the world these springs could be screwed up or pop in...
FYI (If any one interested) I ended up undoing the lower ball joints via the 3 mounting bolts.This released the lower control arm enough to slide the springs in easily. Jacked the arm back up and reattached the Ball Joint Mount.
It turns out that it was fortunate to do it this way as I found that a previous owner/mechanic had used miss matched nuts and bolts for the ball joint mounts and all the threads where badly stripped and chewed up. Dodgy as :shocked: ... and could have be disastrous with some serious 4wding load on them. So in went all new high tensile bolts for all the mounts.
So all done... Much huffing and puffing... very happy with he result...
Post Posted: Wed Aug 28, 2013 9:01 pm
Good to see mate. Could you measure from your guard to the middle of the hub at the front at full droop and ride height please?
Zook Gods knew you needed to find the dodgies.
Well done.
Post Posted: Wed Aug 28, 2013 9:18 pm
I will when the guards go back on... all the panels and guards are off at the moment getting ready for respray.
Happy to measure from another fixed point for you. But from my measurements its nearly 75mm increase at full droop over standard.
Pretty happy with the Price and Value for Money with the Iron man stuff... Thanks to 4wd trekmaster.>> http://www.4x4suspensionbrisbane.com for looking after me. Did me a awesome deal. Better than the cheap crap on Evilbay i was going to buy.
Post Posted: Thu Aug 29, 2013 1:06 pm
Greg is the man!
Vehicle: 1995 Vitara, SWB
Post Posted: Thu Aug 29, 2013 1:42 pm
These look a little familiar.
Yours look much cleaner though. Armsup Armsup
Post Posted: Thu Aug 29, 2013 6:39 pm
Hopefully not for long 8)
Post Posted: Thu Aug 29, 2013 6:40 pm
bigrig91 wrote:
Greg is the man!
Sure is ... Thanks for the heads up
Users browsing this forum: Google [Bot] and 63 guests
