It is currently Tue Nov 03, 2026 7:20 am
Vehicle: Suzuki Sierra
Post Posted: Tue Sep 10, 2013 7:45 am
Hey all
Ive got a 97 coily and wondering what people think is the best engine to put in them on a budget?
Cheers ben
Post Posted: Tue Sep 10, 2013 8:01 am
maintain your current engine is the cheapest option on a budget. If you're running larger tyres, find a way to address the gearing.
Post Posted: Tue Sep 10, 2013 8:17 am
Only got 29s on it
Im just looking for something that goes harder
Post Posted: Tue Sep 10, 2013 8:29 am
An engine swap, go harder, and on a budget don't really go together, especially if you add "legal" to that.
I'd suggest a g16b. Should be possible for between $2k and $4k, depending on your own level of skill and price you get a donor motor for.
Post Posted: Tue Sep 10, 2013 8:39 am
Thanks steve
Vehicle: SJ70 1993
Post Posted: Tue Sep 10, 2013 8:48 am
if your patient you can do it cheap.
i got my G16B for $600 with gear box. but opt for the adapter to sierra gearbox was a benT for $180 i think?
between myself and my mechanic friend and auto elecy brother we did it all our selves over 4 weeks (we did it in our spare time)
Post Posted: Tue Sep 10, 2013 8:51 am
Okay cool mate where did you get your motor from
Post Posted: Tue Sep 10, 2013 9:15 am
FYI - 29's are almost 12% larger than stock 26's... do the gearing.
Post Posted: Tue Sep 10, 2013 9:17 am
Hiw do i do the gearing?
Post Posted: Tue Sep 10, 2013 9:41 am
Fit a gear drive transfer case. It will correct road gearing and lower low range quite a bit.
Post Posted: Tue Sep 10, 2013 9:45 am
Were do you get one of them from? Can you buy them new?
Vehicle: WT sierra, GU CRD
Post Posted: Tue Sep 10, 2013 9:48 am
Seach here or ebay for a "switch light 1 litre transfer case"
I love ZD30. :)
Post Posted: Tue Sep 10, 2013 10:05 am
Cant find anything on ebay under Switch light 1 liter transfer case
Post Posted: Tue Sep 10, 2013 12:58 pm
You are looking for a 1 litre transfer case with a 4wd switch light. I assumed you would search up 1 litre transfers here first to find out what the hell I mean by switch light 1 litre transfer case.
There are none for sale at the moment here or ebay but they do come up, and you will need to move fast when one does. They are an easy and cheap(er) gearing option and hence the demand is high.
Alternatively you could do an after market gear set, + a later model case, way more dear than a 1 litre case at around 150 for the core case and 5-600 for gears plus any new bearings and seals (or shafts :shocked: ).
I love ZD30. :)
Post Posted: Tue Sep 10, 2013 3:01 pm
Just bolt in a supercharged LS7 Armsup
Another option for regearing a jimny is the auto transfer case swap that Shep did recently.
Vehicle: SJ70 1993
Post Posted: Tue Sep 10, 2013 4:54 pm
got my engine from this site. just keep an eye out
Vehicle: Suzuki Sierra 1996 Coily
Post Posted: Thu Sep 12, 2013 1:52 pm
Hey guys anyone know if a 2 ltr ford focus engine would work/has anyone tried to do this conversion and how hard/expensive is it to legally do an engine conversion in WA
Post Posted: Thu Sep 12, 2013 1:54 pm
Post Posted: Thu Sep 12, 2013 5:00 pm
^^ :lol:
No. Probably not. Very hard. Expensive. Consult engineer
You would be out on your own trying to get that engine to work. I doubt there are gearbox options that will work and you will also have to deal with the factory immobiliser too. Just because you may be able to get an engine cheap doesnt make it worthwhile. Staying within the Suzuki platform with a G16B or a J20A are the best options, its all been done before and is mostly bolt in and do some wiring. If I had to pick something outside what suzuki made I would be after something that was all alloy and was able to take an AW4 auto.
Post Posted: Thu Sep 12, 2013 5:24 pm
Ok cool thanks yeah its just I was told that there was a 2ltr engine that would work do you know which one that is??
Post Posted: Thu Sep 12, 2013 5:34 pm
J20a, needs a vitara gearbox swap though and that requires lots of cutting and welding.
Post Posted: Thu Sep 12, 2013 5:38 pm
Spookie wrote:
Hey all
Cheers ben
G16B :deadhorse:
Post Posted: Thu Sep 12, 2013 5:39 pm
You sure? Jonno reckons G13bs are pretty good.
Post Posted: Thu Sep 12, 2013 6:49 pm
^^^ And I think that g13a's are fully sick
I think that there's more ways than LS engines to make power but apparently thats Gaaay!
Anyway:
The OP already has a wanted ad for G16b: viewtopic.php?f=8&t=42887
Doesn't seem interested in gearing.
I love ZD30. :)
Post Posted: Thu Sep 12, 2013 6:54 pm
F10as are the best and everyone knows it. :D
Post Posted: Thu Sep 12, 2013 7:16 pm
G13a :thefinger:
I love ZD30. :)
Vehicle: 94' part 'OCD' sierra
Post Posted: Fri Sep 13, 2013 4:27 pm
Sell or swap me your fuel tank then go from there...!
Users browsing this forum: No registered users and 83 guests
