It is currently Sat Oct 31, 2026 10:10 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Post Posted: Tue Oct 08, 2013 7:54 am
The first Holden Combos ran a pair of single parabolic leafs in the back and they were long. Food for thought.
Post Posted: Tue Oct 08, 2013 8:13 am
As do transit vans. A possible concern with the combo springs is they aren't designed to counter any drive torque.
Vehicle: Suzuki Sierra Stockman
Post Posted: Tue Oct 08, 2013 8:26 am
There we go, it took a while but we got there in the end. Thank you for your informative response as too why the spring rate won't work it makes perfect sense now. If that's the case I will steer well clear of them. I have just found out we have a custom spring works in the Bay so I'm going to shoot out there now and see what they can do for me.
Thnx again.
Vehicle: WT sierra, GU CRD
Post Posted: Tue Oct 08, 2013 11:37 am
Because of the additional, excessive camber on a Calmini spring to achieve 3" of lift, once you remove enough leaves to get the spring to work, there's inadequate spring rate to prevent terminal axle wrap and keep the axle in position. The springs will also be vulnerable to bending as there will be too much main leaf unsupported.
Sounds like you need to find this out for yourself though- go right ahead.
You'll find ultimately that chasing increased rear wheel travel is a whole lot of work that actually does very little for the capability of the car.
I thought it would come back to axle wrap / spring damage.
Edit: finished my post off.
I love ZD30. :)
Post Posted: Tue Oct 08, 2013 8:23 pm
Now that explains it much clearer!!!! I did put a reply here but it seems to not have worked. If that's the case I'll steer clear of em. Just being told they are crap and won't work doesn't cut it for me. But I can see what your saying about the camber used to achieve 3'' won't work when fattened out, thnx for the advice.
Users browsing this forum: Google [Bot] and 69 guests
