It is currently Sun Nov 01, 2026 5:10 am
Post Posted: Mon Nov 11, 2013 11:21 am
Has anyone put vitara power steering on their sierra and had a problem with the steering arms rubbing together after moving the diff forward?
Is there another (shorter) pitman arm I can change to?
Post Posted: Mon Nov 11, 2013 11:23 am
the vitara one is the shorter one.
you have moved your diff too far forward
Post Posted: Mon Nov 11, 2013 11:49 am
Or the box not forward enough.
Are you running bumpstop spacing? This will normally prevent any serious contact.
Post Posted: Mon Nov 11, 2013 1:18 pm
I've got 1" extended bumpstops, the steering is only just touching on compression, I might go 40mm bumpstop spacers.
Post Posted: Mon Nov 11, 2013 1:29 pm
how far have you moved the diff donny?
Post Posted: Mon Nov 11, 2013 6:37 pm
Approx 27mm
Post Posted: Mon Nov 11, 2013 6:39 pm
I thought I read people have moved it further forward then that so I assumed it would be ok
Post Posted: Mon Nov 11, 2013 7:08 pm
I chose 22mm to lessen other mods needed.
Mine never hit. I ran OME suspension, shock relocation and extended shackles.
Post Posted: Tue Nov 12, 2013 5:22 am
Mine is about 60mm forward. 50mm bumpstop spacing and Vit power steer. The arms just touch paint, and the pitman clears.
Post Posted: Tue Nov 12, 2013 6:49 am
How much does the RUF move the diff forward on its own?
Post Posted: Tue Nov 12, 2013 6:58 am
Full RUF brings the axle forward approximately 40mm.
Post Posted: Tue Nov 12, 2013 8:26 am
Oh ok, so with the perch re drilled mine is about 65-67 mm forward! That is my problem. Thanks for everyone's help and input!
Users browsing this forum: Google [Bot] and 589 guests
