It is currently Wed Oct 28, 2026 11:30 am
Vehicle: Holden drover
Post Posted: Thu Mar 27, 2014 7:53 pm
I have a 1985 Holden drover with the g13a motor, I was running rough when I purchased it and the other night it just died.
We checked it for spark but it has nothing? There is power at the coil but it doesn't pulse when the engine is cranked?
I was told it could be the distrubter, is there any way to test it?
Any help would be much appreciated.
Post Posted: Fri Mar 28, 2014 1:00 pm
Hi mate try this from the other thread you posted in.
johnmath wrote:
Have you downloaded the SJ413 service manual here: http://www.suzukiinfo.com/sierra/suzuki ... 413fsm.pdf
The procedure for testing the distributor and setting the gap is in the Ignition chapter.
Post Posted: Fri Mar 28, 2014 4:32 pm
Thanks for that, I tested the pulse generator as the manual says.
But the voltage doesn't change when I insert the screw driver as the manual said it should so I take it that means the pulse generator is stuffed.
Is this part available separately or am I better off getting a whole new distrubter?
Post Posted: Sat Mar 29, 2014 12:38 pm
That part should be available separately but I'd probably just place up a wanted add or have a look in the for sale section for a complete working dizzy. They are generally very robust and go for descent prices.
Users browsing this forum: No registered users and 298 guests
