It is currently Mon Oct 26, 2026 2:59 pm
Vehicle: Suzuki Jimny 2004
Post Posted: Wed May 21, 2014 4:34 pm
So I have a 2004 Jimny and want to put in a 2" lift. I dont want the hassle of extending brake lines and the like. What kits are out there, im having trouble even finding much to compare. And with the 2" is it recommended getting corrector bushes or just the spring and shock absorber. This may sound nooby but i've been trying to research myself and its going nowhere. Thanks in advance.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed May 21, 2014 6:33 pm
2" shouldnt be too problematic castor wise, so shouldn't give you death wobbles unless your kingpins are already worn or out of adjustment
Jimnybits
http://www.jimnybits.co.uk/shop/jimny/s ... t_171.html
Jimny 2" / 50mm Pro Comp Lift Kit
not the hardest springs out there, but a good rate, wont bottom out readily and good onroad and offroad.
Jimny 2" / 50mm Avo Premium Suspension Lift Kit
on roads with lots of corrugations you may want less dampening
Jimny 2" / 50mm Trailmaster Lift Kit
i havenot hear much about the trailmaster shocks
snake racing has 50mm coils
http://snakeracing.com.au/store/mega-li ... 0453baf458
old man emu
i had this 40mm lift aswell as jimnybits. i found the ARB lift taller then stock, as it should be, but much softer then the standard spring rate, becoming springbound more freaquently when hiting big bumps fast
Vehicle: 2012 jimny
Post Posted: Fri May 23, 2014 10:26 pm
I have a 2 inch els kit with he coils and I'm very happy with it.
Vehicle: Suzuki Jimny 2008
Post Posted: Fri May 23, 2014 11:38 pm
I have 2" tough dog kit installed. No complaints.
Vehicle: 06 Jimny
Post Posted: Sat May 24, 2014 6:14 pm
I have OME 40mm lift springs and shocks have been very happy and is does seem a little soft,
but touring off the main road its comfortable.
I installed mine as both rear shockers were u/s @ 60k and the car would drag its arse along the ground when loaded up.
the OME was a good fit and rides well when fully loaded. Available from ARB.
Vehicle: 91 Tin Top
Post Posted: Sat May 24, 2014 7:38 pm
And I have a 40mm Dobinsons kit and really,really happy with it.
We do a far bit of touring/camping and it goes really well loaded up without being too bouncy when empty.
Decisions, decisions....... :wink:
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat May 24, 2014 7:50 pm
Dobinsons can do custom spring rates too.
Post Posted: Wed May 28, 2014 5:34 pm
Alright thanks guys, I just bought a snorkel anyway so i gotta save up the dollars again before a lift anyway, cheers
Users browsing this forum: No registered users and 253 guests
