It is currently Mon Oct 26, 2026 2:59 pm
Post Posted: Fri May 30, 2014 2:15 pm
So it turns out I have plenty of asian hub parts but no actual complete hubs.
I do have a set of avm hubs. There missing a few bolts but no biggie.
Are they any good at all? (Running 34s locker and good gearing)?
Post Posted: Fri May 30, 2014 2:27 pm
I ran AVM's with 31 Extreme's, 6.5's and air locked front. Never had an issue with them at all with comp use as well.
I like the internals of them far better than the aisin spring set up
Post Posted: Fri May 30, 2014 3:39 pm
I had some for a bit. They worked. Just hated the little screws that hold the locking cap on.
Post Posted: Fri May 30, 2014 8:07 pm
Cheers guys. I will clean up and run them!
Vehicle: LWB Sierra & XL7
Post Posted: Fri May 30, 2014 9:05 pm
I had the sealed AVM hubs on my Vit, they were fine. Not being fully serviceable, one got some crap inside and started making horrible noises so I bought the shiny fancy ones. Broke them on it's first outing. I wasn't even doing anything difficult. Sent them back under warranty, had them fixed, Sold them.
'92 Vitara & Camper trailer
Post Posted: Fri May 30, 2014 10:25 pm
What broke?
As far as I know AVM is a Brazilian OEM for several other brands - Mile Marker, Rugged Ridge & SuperWinch come to mind - and they are also used by several vehicle manufacturers as OE - I've had no problems with mine (and yes, I do have the "shiny" ones).
Post Posted: Fri May 30, 2014 10:33 pm
Not sure exactly, there was just a note saying, Fixed, tested ok.
I wasn't too impressed, but at least the after sales service from the peope i bought them off was good.
Post Posted: Sat May 31, 2014 4:24 pm
The single piece ones are very good i ran them for years. Ive seen a few patrols with the 2 piece ones stuff up snd the allen key bolts snap onsaid 2 pice ones also
Post Posted: Mon Jun 02, 2014 12:00 pm
So I have mine off and soaking in some degreeser. There off a zook on 31s so I figure they must be ok.
What a pain to get off. Started with a allan key. Then torx bit tapped in then had to dill some + half of the bolts were missing to start with!
I have a pretty good idea how to fix this (will post up latter if it works.)
What's peoples opinions on hib bolts?
Should I ho grade 12 shcs from the start or go cheepies and replace track side?
Users browsing this forum: No registered users and 268 guests
