It is currently Sun Oct 18, 2026 11:11 am
Post Posted: Sat Nov 18, 2006 3:09 am
hi all. thinking of fitting 1600efi vitara motor to my swb sierra. is this a common conversion & are there any mods that need to be done ie: body lift etc. any info would be appreciated.
cheers andrewa. 8)
Post Posted: Sat Nov 18, 2006 3:50 am
Its the most common conversion. 1 Man half a day if he's sober.
Vehicle: 75 Cruiser
Post Posted: Sat Nov 18, 2006 1:25 pm
have you got a 1.3 at the moment?
from 1.3 to 1.6 motor.........
engine mounts are in slightly different positions on the chassis, so you have to either drill some new holes for the bolts, or get some adapter mounts.
the 1.3 gearbox fits the 1.6 motor but you need to drill some hole in your gearbox, unless you get a adapter kit/plate
with the carby models you don't need a body lift but it's a tight squeeze.
I don't know anything about the efi computer stuff though :roll:
Post Posted: Sat Nov 18, 2006 11:36 pm
any idea where i could buy adaptor plate & engine mounts & at what cost. 1.3 to 1.6efi. is a body lift required?
cheers. :)
Post Posted: Sun Nov 19, 2006 4:05 am
suzi sport aty springwood sells them but im pretrty sure you would be able to find them somewhere else.
Post Posted: Sun Nov 19, 2006 2:18 pm
Ok I did a carby to EFI conversion on my Vit. If a carby 1.6 fits with no body lift then a EFI will too the EFI sits lower cauz theres no air cleaner on top of it.
NOW LISTEN HERE! Make sure where ever your getting the 1.6 EFI from you also get the complete front wiring loom including dash wiring, EFI computer, Coil & ignigter, Air Box & MAF sensor (where applicable). I cant stress enough that all this gear needs to come from the same car... THERE ARE 3 different EFI's in Vit's so if your getting it from a wreckers make sure its all from one car. You dont want to go through what i did.. trust me..
Have a look at my home page there is wireing diagrams for all 3 types and some pics on the conversion. If you have any further questions please e-mail me... www.zook4x4.com
Thanks,
Chris
http://www.nbs4x4club.com
Users browsing this forum: Google [Bot] and 298 guests
