It is currently Mon Oct 26, 2026 1:12 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3
Vehicle: Which one?
Post Posted: Fri Aug 08, 2014 12:55 pm
That's like using a hessian bag to cure acne.
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Aug 08, 2014 10:15 pm
You should replace the rear arm bush with the new design. Try that first before removing the lift. Also get the castor measured as suggested earlier. All these things will contribute to the fix.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Aug 09, 2014 12:35 am
Rear arm bushes causing wobble in front diff or rear bushes in front arm causing wobble?
Vehicle: 2009 Jimny
Post Posted: Sat Aug 09, 2014 5:40 am
Rear bushes in front arms.
Post Posted: Sun Aug 10, 2014 9:53 am
Jezza86 wrote:
i have 0.4mm on the top, and it was shimmed to 4kg, but since its done a lot of work. I'm looking at putting these in next time to see how they go.
Where do you buy these from?
 Profile YIM
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Aug 10, 2014 10:00 am
http://m.aliexpress.com/item/1511351889 ... sitedetail
Whoops that a m16 block
http://m.aliexpress.com/item/1052543182.html
Users browsing this forum: Google [Bot] and 329 guests
