| Author |
Message |
prickle
Vehicle: Suzuki Serria
 Posted: Fri Oct 10, 2014 4:40 pm |
Hi Just bought this today ... it appears to be all original. It's carrying a few wounds .. nothing too serious .. and hasn't been registered for a number of years .. I'll be changing all fluids, draining/ replacing coolant, needs some work on brake master cylinder, steering box leaks etc .. all this done to get it over the pits SO I'm want to turn this into a vehicle that can handle some rough bush tracks .. not crawler type stuff but close... carry camping gear etc. .. It's a spot I travelled to in a "normal" 4wd so nothing too testing. What's my plan of action.? taller tyres body lift maybe gear change doubt if I will need a winch
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Fri Oct 10, 2014 5:09 pm |
That tray looks to be in better condition than just about every original tray I've seen.
Seth2013
Vehicle: 2003 Suziki Jimny
 Posted: Fri Oct 10, 2014 5:55 pm |
looks to be a really good find - all the best with your plans
DarkHorse
 Posted: Fri Oct 10, 2014 7:01 pm |
Nice one. Wish I had the time/space for a LWB Sierra. To get you started: Suspension (not body) lift - search for RUF Gears - diff gear swaps are fairly easy, transfer gears a little harder, (while you're at it get some WT diffs modded to NT spring spacing) THEN Tyres If you decide you couldn't be bothered with it give me a yell.
prickle
 Posted: Sat Oct 11, 2014 9:41 am |
DarkHorse wrote: Suspension (not body) lift - search for RUF .... Thanks Darkhorse .. I need a priority list OK first up I am a complete novice at this  .. have had 4wd's in the past but either already moded or stock standard SO RUF ( what does that stand for) Found this viewtopic.php?f=1&t=21321&highlight=ruf .. a good how to But what is the gain from this mod?? Stuart
atari4x4
 Posted: Sat Oct 11, 2014 9:57 am |
DarkHorse
 Posted: Sat Oct 11, 2014 10:24 am |
want33s wrote: basketcase wrote: But that is still not a full RUF. One of the main reasons for RUF is to move the diff forward to get a better balance and move the tyre away from the fire wall for better clearance. No... the main reason to RUF your car is to get a longer spring under it, hence a smoother ride and more articulation. Moving the diff forward is only a priority IF you want to run large tyres. Some of the most capable Zooks I've ever seen have been on 235/75 tyres. Have a good read through those threads - the discussion about method and motivation is more useful than someone just telling you "this is how you do a RUF."
atari4x4
 Posted: Sat Oct 11, 2014 10:33 am |
^^^ those 2 & the one prickle found are the golden ones, ajsr's was for more flex where as the 2 done by 2stroker are more of a balanced all rounder
303zuke
 Posted: Sat Oct 11, 2014 11:08 am |
prickle wrote: I'm want to turn this into a vehicle that can handle some rough bush tracks .. not crawler type stuff but close... carry camping gear etc. .. It's a spot I travelled to in a "normal" 4wd so nothing too testing.
taller tyres body lift maybe gear change doubt if I will need a winch For mild off roading, I don't think you'd need to go to the trouble, expense and legal issues of doing a RUF. For your needs, I'd say a simple ARB 40mm suspension lift, 215/75-15 M/T tyres on the stock rims, or 235/75/15 M/Ts on 15x6 wheels and a WT Sierra front clip (your left guard needs fixing where it meets the grill panel, and the JA guards will look crap with aftermarket flares.). Despite what others have suggested, I'd strongly recommend either 4.16 or 4.9 transfer gears. If you're mechanically handy, they're easy to install. Even for mild offroading, they're the best improvement for the money you can do to a Sierra. Love the Ute, next best Suzuki after an LJ!
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sat Oct 11, 2014 11:33 am |
303zuke wrote: prickle wrote: I'm want to turn this into a vehicle that can handle some rough bush tracks .. not crawler type stuff but close... carry camping gear etc. .. It's a spot I travelled to in a "normal" 4wd so nothing too testing.
taller tyres body lift maybe gear change doubt if I will need a winch For mild off roading, I don't think you'd need to go to the trouble, expense and legal issues of doing a RUF. For your needs, I'd say a simple ARB 40mm suspension lift, 215/75-15 M/T tyres on the stock rims, or 235/75/15 M/Ts on 15x6 wheels and a WT Sierra front clip (your left guard needs fixing where it meets the grill panel, and the JA guards will look crap with aftermarket flares.). Despite what others have suggested, I'd strongly recommend either 4.16 or 4.9 transfer gears. If you're mechanically handy, they're easy to install. Even for mild offroading, they're the best improvement for the money you can do to a Sierra. Love the Ute, next best Suzuki after an LJ! This x lots. A ruf is miles from necessary on a Sierra and you can get the stock length leafs to flex more than well enough for what you will do anyway. I'd do what 303 says and throw an airlocker in the back, it'l be legal, reliable, capable, trouble free and even drive pretty well for a Sierra. That's an awesome find, I'd love to find one like that.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Sat Oct 11, 2014 3:22 pm |
Just tidy it up and do the servicing and little things a 25-30yo 4wd needs Then drive it for a while and go from there regards to mods
yareckonillgetupthat
Vehicle: 1994 sierra
 Posted: Sat Oct 11, 2014 6:38 pm |
i bought a stock 200 dollar sierra i fixed it up got rego , i havent lifted it yet or up sized wheels but ive put a auto locker in the rear and it leaves luxes and navaras behind
prickle
 Posted: Sun Oct 12, 2014 8:29 am |
Thanks for the comments gents .. first step is to get it regoed Ok so I have had a good look over the car and there are a few things that will have to be fixed. 1. Oil leak on transmission output shaft + whining sound in neutral which the manual suggests is either low oil or worn input shaft bearing / main bearing... oil level is ok .. so do I replace bearings or just replace box with second hand one ($50 on gumtree at the moment) .. aim I buying someone elses problem???? 2. Manual and it suggests to replace clutch if you have the gearbox out.. given the HIGH kms on the car this is probably a good thing ( I don't know what condition the clutch is in as I con't take it for a spin ..no rego) 2B . As I will havethe transfer case out do I do the reduction gears at the same time .. is it a bit job just to pull the transfer box out?? (I will find out soon I guess) 3 Oil leaks around steering knuckles .. a couple of kits to repair. 4. Master brake cylinder leak .. repair or replace? 5 Fluid leak from steering box .. not sure what to about that .. would love power steering .. is that possible on a bog standard motor .. degree of difficulty? 6. Front Left guard ... prang has buckled the engine bay panel as well .. is it an "easy" task to replace ??? .. all bolts / screws no spot welds?? The chances of scoring WT panels (in Tasmania) as suggests by 303 above seems remote Anyway a bit of a list to go on with
sideways
 Posted: Sun Oct 12, 2014 10:15 am |
prickle wrote: Thanks for the comments gents .. first step is to get it regoed Ok so I have had a good look over the car and there are a few things that will have to be fixed. 1. Oil leak on transmission output shaft + whining sound in neutral which the manual suggests is either low oil or worn input shaft bearing / main bearing... oil level is ok .. so do I replace bearings or just replace box with second hand one ($50 on gumtree at the moment) .. aim I buying someone elses problem???? I don't think I've driven a Sierra that didn't have a whine in neutral, I wouldn't worry about it unless it's very loud. Second hand parts are always a gamble. Something to consider, being an SJ50 yours has a 0.8 5th gear. WTs and coilys had a 0.865 5th. The gearboxes are otherwise pretty well identical.2. Manual and it suggests to replace clutch if you have the gearbox out.. given the HIGH kms on the car this is probably a good thing ( I don't know what condition the clutch is in as I con't take it for a spin ..no rego) 2B . As I will have the transfer case out do I do the reduction gears at the same time .. is it a bit job just to pull the transfer box out?? (I will find out soon I guess) It's very tight, but you don't need to pull the transfer out to get the gearbox out. Either way, transfer out (as with any job on a Sierra) is very easy.3 Oil leaks around steering knuckles .. a couple of kits to repair. Be careful to use quality seals, crap will leak after a few thousand kms. 4. Master brake cylinder leak .. repair or replace? New one from 4WD Products is $139.5 Fluid leak from steering box .. not sure what to about that .. would love power steering .. is that possible on a bog standard motor .. degree of difficulty? Bolt on (almost) the setup from a G13bb powered Jimny or use a BenT kit with a Vitara setup.6. Front Left guard ... prang has buckled the engine bay panel as well .. is it an "easy" task to replace ??? .. all bolts / screws no spot welds?? The chances of scoring WT panels (in Tasmania) as suggests by 303 above seems remote Yeah, bolts off. Easy job. See here for a guide on that. viewtopic.php?f=17&t=36562
You will be much more likely to find a WT front clip in decent condition than any others.Anyway a bit of a list to go on with
prickle
 Posted: Sun Oct 12, 2014 3:02 pm |
DarkHorse
 Posted: Sun Oct 12, 2014 3:31 pm |
Depends how annoying the light on the dash will be for you...?
prickle
 Posted: Sun Oct 12, 2014 4:59 pm |
DarkHorse wrote: Depends how annoying the light on the dash will be for you...? If that's the only difference .. I'll disconnect it.  Is it possible to replace the rear oil seal on the gearbox with the box still in place ?? Regards Stuart
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Sun Oct 12, 2014 5:19 pm |
prickle wrote: Is it possible to replace the rear oil seal on the gearbox with the box still in place ??
Yep, transfer needs to come out to get the jackshaft out.
_________________ Quote: I like the tuna here
prickle
 Posted: Sun Oct 12, 2014 5:22 pm |
Blkfxx wrote: prickle wrote: Is it possible to replace the rear oil seal on the gearbox with the box still in place ??
Yep, transfer needs to come out to get the jackshaft out. Great ... Thanks ..
prickle
 Posted: Tue Oct 14, 2014 2:18 pm |
303zuke wrote: ................. WT Sierra front clip Looks as if I found a donor  .. so it's a straight swap??  And what I do with the rear wheel arches one my Suz ? Stuart
dougies_tx5turbo
Joined: Tue May 25, 2010 10:56 am Posts: 1051 Location: north brisbane
 Posted: Wed Oct 15, 2014 9:38 am |
The tray is wider so abit of rubber fairing should look good for bigger tyres look at over people rigs to get ideas
