It is currently Mon Oct 26, 2026 6:21 am
Vehicle: suzuki sierra
Post Posted: Fri Jan 16, 2015 2:29 pm
I have just bought my first Suzuki sierra.its a 1991 swb sierra jx.the guy said its had a suspension lift.the car is very bouncy on road and offroad.can any one please give me a few tips on how to fix this problem.this st uff is all new to me. cheers
Post Posted: Fri Jan 16, 2015 3:32 pm
What tyre pressures are you running ?
Post Posted: Fri Jan 16, 2015 3:47 pm
tyres are 235/75r 15.tyre pressure 36psi
Post Posted: Fri Jan 16, 2015 3:48 pm
Drop to 22psi.
Post Posted: Fri Jan 16, 2015 4:59 pm
isn't that a bit low.the tyre max pressure is 41psi so it sais on the tyre.im driving on the road mostly.and the beach 40percent thanks
Post Posted: Fri Jan 16, 2015 5:13 pm
Not for a light wieght Sierra, most guys run low to mid 20's on road. It wont get rid of the problem but will definitely reduce it and is the easiest thing to do first and is a very common mistake new owners make ;)
Post Posted: Fri Jan 16, 2015 5:21 pm
Have a look at the maximum load rating of the tyre. I bet it's more than the whole car weighs. That's why you don't need 41psi in the tyre.
Post Posted: Fri Jan 16, 2015 5:26 pm
not sure if sierras has a tyre placard but in the jimmy, the recommended pressure is 23-26
Post Posted: Fri Jan 16, 2015 5:34 pm
20 psi for a Sierra. And that's with a tyre with a very low load rating
Post Posted: Fri Jan 16, 2015 5:39 pm
max load rating is 1000kg.is that load rating for one tyre or 4 tyres put together.
Post Posted: Fri Jan 16, 2015 5:54 pm
That will be for one tire
Post Posted: Fri Jan 16, 2015 6:13 pm
X2. That's one tyre.
Post Posted: Fri Jan 16, 2015 6:17 pm
22 psi on road should be about right
5-10psi off road
Post Posted: Fri Jan 16, 2015 6:21 pm
god im a wan__r. my hilux tyres are max load of 1030kg and the car .weighs nearly 3000kg.so I will let them down to 25psi and try that.thanks for all your help guys and girls.
Post Posted: Fri Jan 16, 2015 6:39 pm
went for a drive in some soft sand down the beach.put car in low range and the sierra just cruised through it.in the hilux it would of been totally different.so if I drop the tyre pressure its going to be even easyer. starting to like the sierra cheers
Users browsing this forum: Google [Bot] and 282 guests
