It is currently Sat Oct 24, 2026 12:47 am
Vehicle: Vit swb 95
Post Posted: Thu Apr 09, 2015 1:48 pm
Hey guys,
Was up at Stockton on the long weekend and it looks like ive blown some sort of oil seal in the 2L v6.
Used about 9L of oil in 500ks, and car is burning it all off. Oil leak looks like its coming from the passenger side, rear (near the dip stick for the gearbox oil?)
Anyone know what type of seal could be blown? Easy diy fix?
cheers,
Sam
Post Posted: Thu Apr 09, 2015 7:08 pm
rear main seal
Vehicle: Vit swb 95
Post Posted: Fri Apr 10, 2015 6:08 am
Looked like the oil was coming out abov. They hard to replace Atari?
Vehicle: Which one?
Post Posted: Fri Apr 10, 2015 6:35 am
Rear main is easy to replace; getting to it is the time consuming bit (ever changed a clutch?).
Post Posted: Fri Apr 10, 2015 6:50 am
Can you get pics? Oil leaks can sometimes be hard to chase. Might be best to degrease it then run it. If it's using that much oil it should be pretty obvious
Vehicle: Vit swb 95
Post Posted: Fri Apr 10, 2015 11:59 am
Front crank seal, Rear main, Rocker cover. Oil in the clutch. Great... -_-
Users browsing this forum: No registered users and 103 guests
