It is currently Wed Oct 21, 2026 7:15 am
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3
Post Posted: Fri Sep 11, 2009 3:37 pm
yes you do.please.
navara on 33s. hopfully rear air locker soon
Post Posted: Fri Sep 11, 2009 3:38 pm
Done.
All sizes within 2mm..
Suzy. 91' wt SWB with -28 rims 1372mm
SuzyII. 88' wt LWB with stocko's 1295mm
Lola. 77' Corolla with stocko's 1285mm
Barra. 09' Bunnings wheelbarrow. 0mm (Dont ask me on wheel base)
I dont have anything else here atm to measure the centre to centre of rim track width.
Does that help any!?
Post Posted: Fri Sep 11, 2009 3:44 pm
im 1inch narrower. Will double cheak when i get home
Post Posted: Fri Sep 11, 2009 3:50 pm
is that measurment taken from the back? As i think front may be affect by steering even if it looks straight could be out a bit
Post Posted: Fri Sep 11, 2009 3:52 pm
All measurements are from the back. Except for Barra..
My tyres are on 28psi.. Suzy is parked on a tiny slope. But should'nt move the tyre much so thats why i said within 2mm just in case to confirm sizes.
Post Posted: Fri Sep 11, 2009 3:54 pm
thanks. Massave help.
Post Posted: Fri Sep 11, 2009 9:58 pm
WT LWB 32's -28 rims = 1380ish
LWB 35's 60 series diffs = 1525 Armsup
Member of C.O.R 4x4
Post Posted: Fri Sep 11, 2009 10:10 pm
yer im guessing my rims are -28. im getting the 1370ish
Post Posted: Fri Sep 11, 2009 10:32 pm
your possiable the most hated man on AZ at the moment... :D
Post Posted: Fri Sep 11, 2009 10:51 pm
:thefinger: Armsup peaceout
Member of C.O.R 4x4
Post Posted: Sat Sep 12, 2009 2:35 pm
Im 1490 front and 1445 rear on lu diffs.
If anyone has lux diffs could they run a tape over them I need to know if all toys are 50mm wider in the front, maybe you guys could be more helpful than toyota guys :roll:
Nik
No zooks just VWs
Post Posted: Sun Sep 13, 2009 6:25 pm
Just measured mine (35X11.5X15) on 15X8 rims, and on lux front diff housing, and bundy rear housing. Front, 1505mm.. and the rear 1465..
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Sun Sep 13, 2009 7:25 pm
Was that with the bundy rear?
Im trying to find out why my front is 50mm wider than the rear.
My rear is 1410 from wms to wms front is 1460.
Thanks Nik
No zooks just VWs
Post Posted: Sun Sep 13, 2009 8:14 pm
Thanks Nik
Check my original post, i just made some changes to it! hehe
Post Posted: Sun Sep 13, 2009 10:41 pm
haha thats better :D
Thanks for that so 40mm difference!
Been talking to toyota nuts and they are baffled as toyota lists the "standard" track as 1420 front 1400 rear only 20mm difference!
Nik
No zooks just VWs
Users browsing this forum: No registered users and 109 guests
