It is currently Sat Oct 24, 2026 1:37 am
Post Posted: Fri Jun 05, 2015 2:38 am
Hi i want to install wider and a little stronger rear axle on my coily.
can i put coily rear center on vitara rear axle case?
Post Posted: Fri Jun 05, 2015 7:18 am
No. Best option would be a sidekick/Vitara based full float axle, but you can't get 3.9 gears for a Vitara diff.
Post Posted: Fri Jun 05, 2015 3:15 pm
Steve thank you for your answer.
How bout put the front corona & pinion out of front side kick and put it inside of the coily front axle?
will it work?
Post Posted: Fri Jun 05, 2015 4:30 pm
NO, coilys use a hi pinion front and there are no replacement gearsets for them
Post Posted: Fri Jun 05, 2015 9:11 pm
Errrrr...
Well thanks for your answerd.
Post Posted: Sat Jun 06, 2015 3:21 pm
Another chance...
how put complete rear axle out of vitara with 4.3 ratio.
and in the front stuff inside coily center jimny 4.3 ratio?
will this work?
Post Posted: Sat Jun 06, 2015 5:42 pm
Coily front is unique ,so you can't change anything with anything. if your going down the path of custom rear then why not a whole jimny front in 4.3 to match the 4.3 rear.
You could fix some of the coily problems in the suspension , then you could get a front locker as well and I think tanishi offers chromoly cv's for jimny Diffs .
Obviously this won't be cheap but it's just a suggestion .
Could also get a floating axel kit for the rear if your current diff and some wheel spaces.
Is it the housing that's to week or the axles?
Post Posted: Tue Jun 09, 2015 8:08 am
what are you trying to achieve, on the whole unless your running 35s+ you wont have too many strength issues with the rear.
HD axles can be gotten for them if your breaking them.
Users browsing this forum: Google [Bot] and 117 guests
