It is currently Sat Oct 24, 2026 3:02 pm
Vehicle: 2003 Suziki Jimny
Post Posted: Fri Jun 12, 2015 1:19 pm
hey
weird issue - whenever I am on even a slight incline, all the washer bottle water runs out the back window washer nozzle, which is cute if you get stuck on a hill, looks like its pissing itself with fear. is there something I can do to fix this.
Post Posted: Fri Jun 12, 2015 1:39 pm
nothing to fix. its how the washers work, if you stop that you will stop the rear washer working
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jun 12, 2015 3:11 pm
i have never, ever noticed this.
Post Posted: Fri Jun 12, 2015 5:02 pm
Its cus you only have one hill in Gove :thefinger:
My old jim use to do it to
Vehicle: Vitara SV420
Post Posted: Fri Jun 12, 2015 5:22 pm
Seth2013 wrote:
hey
Would could purchase a little one way check valve, or even an aquarium air pump valve and fit this inline to your rear washer nozzle. This should stop this issue.
Hope this helps!! :D
Post Posted: Fri Jun 12, 2015 5:25 pm
Like this, $5 fix!
http://www.theaquariumshop.com.au/shope ... ck%20Valve
Even better, proper valve.
http://www.ebay.com.au/itm/WINDSCREEN-W ... 462d4ac85b
I have used both of these in the past and they have worked well. I only used the aquarium valve as no one had a proper valve in stock, and a pet store was close by. In saying that, it worked just as good. I have found that placing the valve close to the nozzle works best, as opposed to near the washer reservoir. So maybe in your tailgate would be a good place.
Vehicle: 2000 Jimny
Post Posted: Fri Jun 12, 2015 6:21 pm
mine does the same, there's a non-return valve for the rear washer jet in the back door, here's a guide on how to replace it:
http://www.bigjimny.com/images/document ... er_jet.pdf
Post Posted: Mon Jun 15, 2015 11:48 am
cheers guys, this is one of those fixes that will dramatically improve my life. might head to the pet shop see if they have one.
Vehicle: Sj51t
Post Posted: Mon Jun 15, 2015 12:03 pm
My one does it to
I just park it backwords on hills
Users browsing this forum: Google [Bot] and 76 guests
