It is currently Sat Oct 24, 2026 5:39 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
Vehicle: suzuki sierra lwb
Post Posted: Wed Jun 17, 2015 1:36 pm
So if I fit two pod filters will I get boost? After all if one pod filter delivers air faster to the motor, then two must deliver so much air so fast it would be like having a hektik turbo! (Just to be clear, a filter doesn't deliver air, it's drawn by the motor. If the air flows through the pod faster, that's an indication of reduced filtration effectiveness. The goal should be to have the air moving through the filter as slowly as possible.
Are you sure it's the pod filter improving throttle response, or removing restrictive pipe work? And are you happy to reduce filter efficiency in order to improve throttle response? Wouldn't a better solution be a larger filter with increased piping diameter? Then you're not trading off filtration efficiency for flow.
Yes I think u would be correct ...... the pod i suppose is less air restricting so therefor one would think that it dosnt filter the air aswell .biger filters and pipe work should deliver more clean air to the engine
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jun 18, 2015 12:37 pm
larger surface area filters provide less restriction without compromising filtration capacity/ efficiency.
oiled filters by design (and through physics) use electrostatic principals to catch dust on oil. this works great on 10 micorn and above particles (if you oil the filter correctly. the electrostatic effects diminish as particle size decreases.
as such oiled filters will work great around coal mines, but shithouse around ladraritic ore mines such as bauxite and nickel mines. obviously the dertier the filter the less effectively it works as the sticky oil becomes caked on, and there is no available sticky surface area to grab new particles.
new paper filters can also let through particles, however as the particles acumulate on the filter you get better filtration, by formation of a filter cake. this is 5-10 micron materiel trapped on the filter, that stops the <1 micron duct that otherwise wouldn't be caught by the filter.
Users browsing this forum: No registered users and 387 guests
