It is currently Thu Oct 22, 2026 7:19 pm
Post Posted: Mon Sep 14, 2009 12:37 am
Hey my shorty now clicks a couple of times before it starts and sometimes it doesn't start. I pulled my lwb one apart and its simple enuff but, is there any easy way of getting the starter motor out? what part usually dies?
cheers
Post Posted: Mon Sep 14, 2009 1:02 am
Mate it is usually the brushes that wear in them. They can get sole kid problems that also cause the same problem that you are having.. They aren't expensive new... I can get them for 150 if the car is a 1.3
they really aren't hard to get out I reckon it is getting them back in that's the hard part
Post Posted: Mon Sep 14, 2009 1:06 am
i did have that click clicky think and i think its the battery. i usualy put my battery on charge every 2week to top it up
navara on 33s. hopfully rear air locker soon
Post Posted: Mon Sep 14, 2009 1:10 am
hey mate, did this a few days ago pulled the starter motor out and greases and cleaned it up. starts like new now. 3 bolts if i remember rightly and just drop it down in front of the diff. straightforward to pull apart aswell. just remember to disconnect your battery. :roll:
Post Posted: Mon Sep 14, 2009 9:49 am
cheers fullas :D 150 gosh thats alot more than grinder brushes... so does it sound like crap on the brushes or worn out brushes?
Post Posted: Mon Sep 14, 2009 10:50 am
$150 would be for a whole starter motor
Post Posted: Tue Sep 15, 2009 1:03 am
haha sorry... I fixed it without taking it out, i pulled my lwb one apart (because it was out) and figured out that there is a push rod that make the actual motor engage so it figured that it must sit still for the time that im driving and only turn when asked. So when it started I held the key on so that the starter motor would do an extra couple of revolutions and now for some reason it starts first go. I can only guess there was muck on the contacts and the extra couple of revolutions may have cleared it...
If this is a bad idea then please tell me...
I was impressed anyway never been able to fix the motor from the drivers seat...lol :D
Post Posted: Tue Sep 15, 2009 2:08 am
I`ve done the same, starter still going :D
Vehicle: WR250F/Jeep XJ
Post Posted: Tue Sep 15, 2009 5:29 am
Mate hook up a relay and run direct battery current to your postive terminal on the starter motor. Zook standard wiring sucks and as the cars get older so does the wiring. The standard wiring runs thorugh the loom so lots of voltage drop so if you hook up a wire straight off the battery to the starter, controlled with a relay it should give it more guts to kick it over.
I even found a wiring diagram for you:
http://zukioffroad.com/Tech_Library/starter_relay.htm
too easy!
Post Posted: Tue Sep 15, 2009 11:32 am
cheers dank:D it looks like one of those non hardcore mods that make ya car so much more easy to drive...
Users browsing this forum: Jusmud and 169 guests
