It is currently Thu Oct 22, 2026 2:40 am
Post Posted: Mon Jan 11, 2016 1:51 pm
Hey all,
Just noticed EFS are now making a 65mm lift unlike the common 50mm lift for the sierra. I'm going to assume its just the 50mm leafs with an added leaf or two probably.. But has anyone fitted them or had experience with the EFS springs in their zuki's?
I've heard some good and bad about them, but that was on much bigger and heavier cars. as we all know suspension is hugley different from car to car.
Cheers :)
Post Posted: Mon Jan 11, 2016 1:57 pm
I can't see a reason a Sierra needs 65mm of extra compression travel.
I'm aware of the leaves being used with heavy engine conversions or de-rated to provide lots of travel with a lower ride height.
Vehicle: 98 Jimny
Post Posted: Mon Jan 11, 2016 2:21 pm
Honestly stick to the 50mm, which once you realise how stuff the springs are without constant weight, will drop down to about 40-45mm as you'll take a leaf or two out.
But, EFS springs work well with our cars providing you get a good shock absorber with it. Many people on here run them and are very happy with them.
Post Posted: Mon Jan 11, 2016 2:42 pm
Good shocks aren't a problem, have a friend working at King Springs and he's sourcing me some remote adjustable shocks for it. Should run sweet :)
Post Posted: Mon Jan 11, 2016 4:10 pm
I like the efs 65mm as they are longer than the majority of 50mm springs on the market giving slightly better shackle angle and smoother ride once they settle. That 65mm turns into 50mm pretty quick with regular offroad use but because of the extra length the standard rear shackles have a tendency to invert
Post Posted: Mon Jan 11, 2016 11:08 pm
Alright no worried sounds good! How do the 65mm springs handle weight? Have you had them loaded before? I'm assuming you have them in your own rig..
Post Posted: Tue Jan 12, 2016 9:10 am
Yeah i remove the load leaf (bottom fat one) to soften them a bit quicker but i had around 250kg+ in the tub for 1200+ km trip over xmas and to be honest it could have done with the load leaf being in but i only do 2-3 trips like that a year so id rather a softer ride 99% of the time
Post Posted: Tue Jan 12, 2016 12:28 pm
Yeah to be honest the rougher ride doesn't bother me at all, I've owned plenty of zuki's in the past its just a zuki thing.. I want weight handling. I'm planning on doing massive trips, and I mean like 2000km or more with 300 or more kg in the back. So I need the load spring. I've always loved zukis and my plan is to make one a tourer .. a lot of people said its not possible. I'm making it possible.
Post Posted: Tue Jan 12, 2016 2:27 pm
I dare say i thought of an airbag type setup
Efs also do a hd lwb spring that flexs shitza but handles the weight with ease
Shackle angle is about 20* the opposite way with lots of spring arc
The ride is terrible unless its loaded
Post Posted: Tue Jan 12, 2016 2:28 pm
They list it as a hd lwb spring but it also will fit a swb
Also will be more like 80mm when unloaded
Post Posted: Tue Jan 12, 2016 8:02 pm
So the 65mm swb springs are ok in a lwb? As im planning on doing a ruf and using the 65mm rear springs with the load leaf out on my maruti
Post Posted: Tue Jan 12, 2016 8:18 pm
That sounds like a plan! The HD springs sound good to me aha
Post Posted: Tue Jan 12, 2016 8:38 pm
At that far over your GVM expect reliability problems.
Users browsing this forum: Google [Bot] and 166 guests
