It is currently Thu Oct 22, 2026 4:34 pm
Post Posted: Sat Sep 19, 2009 10:07 pm
does anyone know if these tailshafts are in the right way or if they will even go in the wrong way
also any ideas as to where i can get a rear output shaft seal for the tc
thanks
brett
Post Posted: Sat Sep 19, 2009 10:08 pm
It doesn't matter which way they go in, so long as the yolks line up.
Post Posted: Sat Sep 19, 2009 10:10 pm
that was fast dude
thankyou
Post Posted: Sat Sep 19, 2009 10:12 pm
kenso wrote:
that was fast dude
thankyou
I don't have a life :roll: :lol:
Post Posted: Sat Sep 19, 2009 10:31 pm
would it be a significant vibration if the yolks were'nt lined up ?
Post Posted: Sat Sep 19, 2009 10:39 pm
Yes. The bigger the angle the uni is working on the more suseptible it is to vibrations. You need to set them up so they cancel each other out. Have a read through Here
Post Posted: Sat Sep 19, 2009 11:23 pm
8O I prefer the rubber boot section up higher near the transfercase to help get it out of the mud and crud... also up ther it allows the water to drain out.
That second pic has some wacky angles on the shaft!
Post Posted: Sat Sep 19, 2009 11:24 pm
thanks mate it was a good read
i wont pretend i understood it all but ive been chasing a vibration in the 50
and both mine were out of alignment so fingers crossed this may solve the problem
i would go and try it now but ive pulled the handbrake and rear seal out or the tc so will have to wait
thanks again
brett
Post Posted: Sat Sep 19, 2009 11:28 pm
its pulled off the transfer so i can get to that bloody seal which was pissing out oil
Post Posted: Sun Sep 20, 2009 6:57 am
From the Suzuki LJ50 manual:
"Match marks are provided on the slip-on spline connections. Inserting the splined end into the splined bore without regard to the match marks can be a possible cause of noise or vibration of the propeller shaft. Be sure to index the marks."
Pop the boot off the shaft and clean away the grease, and you'll see the marks. The boot end towards the transfer case is the right way to fit the shafts.
Post Posted: Sun Sep 20, 2009 3:13 pm
303zuke you have posted a scanned pic from the manual showing index marks, perhaps you could also scan and post a pic for Kenso showing what Scrawn was saying about the yolks lining up. If you have the original manual there is a good pic on page 154 (my scanner is kaput)
303zuke and Hutch are correct, from factory the short end of the tailshaft with the female spline and rubber boot is connected to the transfer box.
Post Posted: Sun Sep 20, 2009 4:34 pm
Your wish is my command, Sire!
Kenso, if you're wondering why your rear shaft doesn't look like the one in the manual, it's because yours is from an LJ80, built bigger for "more torque"!
Post Posted: Sun Sep 20, 2009 4:46 pm
thanks heaps for all the responses
mine were both out so all your help is appreciated
once i get hold of a seal for tc I will let you know if vibration is gone
Users browsing this forum: AdsBot [Google], Google [Bot] and 122 guests
