It is currently Thu Oct 22, 2026 8:20 am
Vehicle: 92 Sierra LWB
Post Posted: Wed Feb 17, 2016 5:10 pm
As the title suggests I have a F10a that, when the temp gauge shows half motor runs great at highway speed (for a 1 litre), but occasionally the temp will be slightly lower than half and it seems to lack power any suggestions? if the thermostats is no good could this effect power?
Thanks
Vehicle: 98 Suzuki Stockman/maruti gyps
Post Posted: Sun Mar 20, 2016 10:43 pm
It seems running the little motor on the highway calls for high revs, leading a lot of air through the radiator from the fan. Which leads to a cooler running temp. Unfortunately I wouldn't know any solutions to fix the "problem", perhaps replacing the sump oil with a more viscous type, so that the oil isn't causing resistance from being colder.
Post Posted: Mon Mar 21, 2016 6:22 am
I bet someone has pulled the thermostat out at some stage. If the car starts to run cold the thermostat should close and maintain temperature.
Start with the thermostat.
Users browsing this forum: No registered users and 297 guests
