It is currently Wed Oct 21, 2026 12:26 pm
Vehicle: 1998 "Coily"
Post Posted: Sat May 14, 2016 1:54 am
Hey guys I bought a 40mm lift kit: http://www.onlineautoparts.com.au/produ ... /ZPN-01806
for my coily and 2.5 degree offset bush kit: http://www.onlineautoparts.com.au/produ ... /ZPN-02507
and had just wanted any tips or tricks you guys might have before I dive into it???
What should I start with? Replacing springs and shocks first or doing the bushings first? Will I need a press to get some of the old bushings out or are there DIY ways to do it? I've see some land rover guys do clever things but want some Zuk guys imput.
Thanks!!
Post Posted: Sat May 14, 2016 10:38 pm
Also anyone have the torque specs for the suspension for a coily?
Post Posted: Sun May 15, 2016 10:20 am
U could use a jack under the chassis rail for a press
Vehicle: LWB Sierra
Post Posted: Mon May 16, 2016 8:51 am
Don't need a press, best way to do it is take the rear shocks off and either flex it up and take one spring out at a time and swap in the new ones or do them both at the same time with a jack.
For the front, undo both top strut mounts and jack the front up with a high lift jack (I go off my steel bulbar) but could just go off the crossmember behind the stock bumper if you don't have a strong bull bar.
then once its up swap over the struts and springs and you're done
Vehicle: LWB Sierra
Post Posted: Mon May 16, 2016 8:53 am
You can put the bushes in without a press using a vice, bearing puller and a hammer
Users browsing this forum: No registered users and 151 guests
