It is currently Wed Oct 21, 2026 9:27 pm
Vehicle: stockman
Post Posted: Mon Sep 19, 2016 5:58 pm
I am so excited, I just picked up my new 1997 JLX Vitara. It's auto with the J20 engine and has a 70lt fuel tank from factory! It is in excellent condition and has done 215000km's.
The only thing I need to ask is it normal for the gearbox to be clunky when going from park into gear and shifts a bit clunky? Can these autos be served and repaired sucessfully if need be?
Any knowledgeable answers appreciated.
Post Posted: Mon Sep 19, 2016 6:45 pm
Depends on how quickly it's shifting. If it shifts quick that's fine. if it's slow, especially from D to R, then that's a sign of wear. Transmission is an AW-4 and is generally very durable.
It's possible the clunk isn't from the auto at all but is from a worn rear A arm ball joint or worn uni joints.
Vehicle: stockman
Post Posted: Mon Sep 19, 2016 8:11 pm
Thanks. It clunks going from park to drive/reverse. Shifts ok whilst driving. Sometimes a little lag. Will check the joint and uni's.
Vehicle: vits
Post Posted: Mon Sep 19, 2016 8:33 pm
My guess is the kickdown cable is sticking, this controls the line pressure in the trans, it's a common fault.
Try unhooking the cable from the throttle then shift between D N R to see if it improves.
Post Posted: Tue Sep 20, 2016 7:50 am
Aw4 doesnt use a kickdown cable.
Post Posted: Tue Sep 20, 2016 9:25 am
It most certainly does - although I believe it's now called the TV (throttle valve) cable.
Post Posted: Tue Sep 20, 2016 10:11 am
I was going to say mine does too.
Vehicle: 91 jlx coupe and 99 stockman
Post Posted: Tue Sep 20, 2016 7:18 pm
Im pretty sure mine has a vacuum actuator valve not a kickdown cable ?
Vehicle: vits
Post Posted: Tue Sep 20, 2016 8:28 pm
Call it what you want. It's the cable from the AW4 trans to the throttle body, it sometimes gets stuck & causes the problem the OP has described.
Users browsing this forum: No registered users and 143 guests
