It is currently Tue Oct 20, 2026 3:14 pm
Vehicle: Searching for a Zook
Post Posted: Sun Apr 01, 2012 8:35 pm
Just wondering what everyone else's Jimny's were costing them?
Vehicle: 07 vvt jimny
Post Posted: Sun Apr 01, 2012 8:41 pm
usually 400km a tank then the light comes on and I get about another 50km
mixed bewteen BP 95 and 98, only 98 on my rich weeks ha ha ha
and im on 235's
sorry CHOP :P
Jimny's Are taking Over
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Apr 01, 2012 8:44 pm
I had been regularly getting around 9.5L/100km from my 2009 VVT Jimny fully loaded for outback travel. Went into the Vic high country last month and got 13 L/100km. I think that was my inexperience, spending too much time in first low range. Was not heavily loaded on that trip. Would be interested to see what others get offroad in mountainous terrain. I use 98 RON and have 215 MT tyres.
Haha, do a quick search mate, fair bit of dribble in the last thread I thought, but with stock tyres I get 400kms to a tank.
http://auszookers.com/forum/viewtopic.p ... ny+economy
Post Posted: Sun Apr 01, 2012 9:09 pm
Sorry :S was on the tablet and it has a siezure doing to much searching at once. I've read that you can expect anywhere from 7.5-9L/100km from a stock one?
Post Posted: Sun Apr 01, 2012 9:11 pm
I got 9L/100 on mainland, around 12in tassie
Vehicle: 2003 Jimny Auto
Post Posted: Sun Apr 01, 2012 9:18 pm
You all get better than I get from my 2003 (non vvt, auto trans)
I think 11L per 100ks is a good day.
Post Posted: Sun Apr 01, 2012 9:26 pm
I am very keen to get a zook and I was just checking to see what the fuel economy was like as I currently spend about $100 a week driving around in a Forester. Would you say 7.5-9L/100km would be a reasonable assumption as to what I should expect?
From a stock Jimny ^^^^
Post Posted: Sun Apr 01, 2012 9:46 pm
jimnys are nowhere near as cheep to run as I had read.
apparently in stock there ok but as soon as you add lift and tires it smashes it.
Post Posted: Sun Apr 01, 2012 10:03 pm
:lol: Stock i would get 450km-500kms to a tank. 31's, with gearing and big lift, about 250-330 to a tank.
Last night Smiffkid got 50km's to 20L :lol: :lol:
As soon as you change any thing from stock, your fuel economy turn's to shit :(
Post Posted: Sun Apr 01, 2012 10:06 pm
Expect 8-12L. Don't expect it to use no fuel at all, and auto's generally use more then manual's.
Vehicle: Jimny, Lifted on 30's
Post Posted: Mon Apr 02, 2012 4:40 am
X 2 on 30's :P
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Mon Apr 02, 2012 5:00 am
Haha. Cheers for the replies. Can't wait to get a Jimny :)
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Tue Apr 03, 2012 10:04 am
I get 300km to a tank but I carry alot of gear all the time.
TasZooks
http://www.facebook.com/TasZooks
Post Posted: Tue Apr 03, 2012 11:14 am
try getting your injectors professionally cleaned guys. did it to mine and seems to have made a difference. took em to a diesel injector place as there werent any petrol ones locally. but they said it didnt matter.
MY BUILD THREAD HERE!!!!!
Post Posted: Tue Apr 03, 2012 12:05 pm
my map sensor line has a filter thing in it. gave that a clean with some carbi clean and blew it out, i think thats given me a bit of better fuel econ + more power
Post Posted: Tue Apr 03, 2012 12:17 pm
i always get 300-350 km in mine :? its a non-vvt tho
Post Posted: Tue Apr 03, 2012 4:27 pm
huh? where?
Post Posted: Tue Apr 03, 2012 5:27 pm
Scales wrote:
huh? where?
g13bb
firewall end of inlet manifold.
Post Posted: Tue Apr 03, 2012 6:56 pm
X 2 on 30's :P
X3 Even with 235's the economy sux. My 1981 323 gets much better economy than my 2010 Jimny.
 Profile YIM
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Jun 29, 2017 11:57 am
Ratshite economy for a small car - 2010 M15A manual, free wheel hubs, 3"lift, 215/75R15 tyres
Mine is using 11+ l/100k so if I get 300km before the low fuel light comes on I'm doing well. Admittedly I drive up and down a mountain to go anywhere but that means lowish speeds not 110km/hr everywhere.
No codes showing, free flow exhaust, (extractors soon). Oxygen sensor tests ok, output is fluctuating wildly (OBD2 and Torque app) but I'm told that is how it works.
I might get the injectors cleaned - mine are grey (200cc) but I have orange in the spares (also 200cc). Not sure what the difference is if both 200cc.
After that I give up!
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Vehicle: Jimny sierra 2011
Post Posted: Wed Jul 19, 2017 5:11 pm
My 2010 model gets 7-8 l/ 100 k but I try to drive it about 90 k/hr. Our roads are hilly here so it does chew it if you put the foot down. I just read the caravan and motorhome magazine on fuel economy and while they are mainly diesels the evidence they tested two lots of identical vehicles and the results show drive at 80 for fuel economy (sometimes life's too short), larger tyres increase fuel use as does the weight of your vehicle. Surprisingly a snorkel will save a bit of fuel because the air is cleaner and cooler. Any load on the roof costs and check tyre pressures a lot more regularly than me and service regularly. Surprise, surprise diesels use less than petrols. They quote a lot of scenarios such as aerodynamic aids work and weight of vans increase fuel use.
Vehicle: Jimny 2012
Post Posted: Thu Jul 20, 2017 12:07 pm
My 2012 gets 500 a tank with 215/75s has roof rack but no bullbar
Vehicle: Vitara 1994
Post Posted: Sun Jul 23, 2017 4:43 pm
One of the biggest factors for killing jimny economy is lift. The jimny is pushing shit uphill already aerodynamicly so as soon as you add a lift things really turn to crap.
Users browsing this forum: Google Adsense [Bot] and 173 guests
