It is currently Tue Oct 20, 2026 8:43 am
Vehicle: On the lookout
Post Posted: Wed May 17, 2017 8:08 am
As per topic heading. Early grand vitara V6 2.5 litre, no immobilisers or complications into an older vitara 2.0 V6. Any issues with this swap? Im actually guessing this is going to be pretty plug n play, but im not sure about how complex the swapping of the ecu is.
Crispy old grand vitara
Vehicle: Vitara,Estate Wagon 97
Post Posted: Fri May 11, 2018 5:38 am
DID YOU FIND OUT ANYTHING ABOUT THE ENGINE SWAP? I'M LOOKING AT SWAPPING MY H20 ENGINE FOR A H25 TO IMPROVE PERFORMANCE AND ECONOMY.
Post Posted: Fri May 18, 2018 3:57 pm
yess!!
viewtopic.php?f=5&t=40912&hilit=h20+h25
viewtopic.php?f=4&t=1842&hilit=h20+h25&start=150
Vehicle: sc100 se416 mightyboy
Post Posted: Sun May 20, 2018 11:30 pm
Easiest way and the way most people go is to source a h25 long and just swap all sensors etc over from your h20 and bolt back in, most sensors are the same anyhow and the wiring ECU currently in the sv620 work fine with the bigger capacity. upgrading to the h25 injectors is recommended also but not essential. swapping the loom from the h25 would not be very easy because of the way the loom is run completely differently between GV and SV models including ECU location.
Why make your Suzuki like a Vitara, Just get one.
Users browsing this forum: No registered users and 210 guests
