| Author |
Message |
Heypresto
Vehicle: Suzuki Jimny, 2001 3dr 4x4
 Posted: Fri Dec 14, 2018 12:19 am |
I've got a 2001 jimny with no roof rails or studs. Would like to get roof racks and only option I've found is a Rhino trackmount. Don't want to drill into roof as leakage!
TIA
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri Dec 14, 2018 9:24 am |
If u use sealed riverts and urethane u won't have leaks
ZUZUKI
Joined: Thu Sep 02, 2010 5:50 am Posts: 427 Location: Melbourne
 Posted: Fri Dec 14, 2018 10:16 pm |
There is no magic to be had. They don't make super glue, Velcro or double sided tape strong enough. Holes in the roof it has to be. Rgs, Michael
vet 180
Vehicle: Vitara 1994
 Posted: Sat Dec 15, 2018 5:07 pm |
ZUZUKI wrote: There is no magic to be had. They don't make super glue, Velcro or double sided tape strong enough. Holes in the roof it has to be. Rgs, Michael This X10 There is technically some glues strong enough, as many new cars (generally aluminum ones) use glue instead of welds throughout the chassis. They have actually done destructive tests on them and they are stronger than welded alternatives. However achieving holes in the roof with no leaks is far less complicated and expensive. Sent from my iPhone using Tapatalk
pete_79
Vehicle: 91 Tin Top
 Posted: Sat Dec 15, 2018 5:12 pm |
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sat Dec 15, 2018 8:46 pm |
Could you use nutserts instead of rivets?
ZUZUKI
 Posted: Mon Dec 17, 2018 6:07 pm |
Rivets get supplied with some / many of the track kits. IMO the rivets / nutserts / rivnuts don't spread the load far enough around the hole they are in. If you are doing this, the best (but not the easiest, quickest or cleanest) way, is to remove the headlining, get some M6 x 12-15mm bolts, nyloc nuts & 25mm+ O.D. panel washers, a tube of windscreen sealing / bonding mastic & away you go. The holes in the tracks may need opening out. The holes and bolts may need to be countersunk (S/S in-hex machine screws) to clear the underside of the cross bars as they slide in the rails. The result should last the life of the vehicle, not leak, not tear out (assuming you stick to the kits load rating) - effectively set & forget. Rgs, Michael
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Dec 27, 2018 8:34 pm |
I had Rhino track mount racks on my LWB Vitara. Drill your holes and put down some silicone around the holes before you put down the track and rivet. I had no leaks or strength problems.
My jimny also has the same roof racks. No issues. They’re a great low profile rack setup in my opinion.
_________________ mlm
