| Author |
Message |
redrocketsj50
Joined: Wed May 19, 2010 9:20 am Posts: 268 Location: Sale victoria
 Posted: Tue Dec 14, 2010 10:34 am |
my one is flogged out so how do u rebuild a sierra steering box ?
pics would be handy
if not does anyone have one that will sell
_________________ Sj80,31 claws, lift, winch, 6.5
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Tue Dec 14, 2010 10:58 am |
Ive got one. No slop. was being used till last weekend. $100.pick up dandenong.
_________________ B4T
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Tue Dec 14, 2010 12:01 pm |
^^ bargain.
how to you know yours is stuffed though? mine was doing all sorts of weird and just needed a shitload of lube jammed in there. (i used bearing grease).
redrocketsj50
 Posted: Wed Dec 15, 2010 9:14 am |
what do u call wierd alien, ? mine u drive in a straight line and the steering wheel is turned half turn to the left :s scary at 100kms .....but the steering wheel and wheels are all straight and alined. there is heaps of play
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Wed Dec 15, 2010 9:18 am |
have you tried adjusting it?
Microwire
Joined: Tue Oct 12, 2010 12:40 am Posts: 543 Location: Casula
Vehicle: Vitara 90'
 Posted: Thu Dec 16, 2010 12:34 am |
My Vit is similar to that, it makes trips exciting, though the pump and box have just started leaking which I'm not to happy about. Are there rebuild kits for them?
tanshi
 Posted: Thu Dec 16, 2010 12:35 am |
wouldnt bother rebuilding, cheep good ones are plentiful, and there is always the powersteer option ontop of that
Microwire
Vehicle: Vitara 90'
 Posted: Thu Dec 16, 2010 1:13 am |
Mine's power. needs fix
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Dec 16, 2010 6:38 am |
AFAIK, there's no rebuild kit. The suzuki factory service manual shows it as a replacement item, not rebuildable.
I'm sure it's possible to pull it down and replace seals etc, but once wear is excessive replacement sector shafts etc would cost more than it's worth to replace the box.
As an aside, (sort of) There is a tensioning procedure. I can't remember the exact figures right now and don't have an FSM handy, but in involves tightening the adjuster until there is measurable preload on the input shaft to the box. Obviously, this is a bit time consuming to do as the the steering shaft and draglink need to be removed to get it to spec, but based on the way I've tensioned boxes in the past (by feel - until you can't feel slop through the steering wheel) generally, steering boxes aren't adjusted up tight enough.
alien
 Posted: Thu Dec 16, 2010 8:47 am |
outterlimits95
Vehicle: 1989 Sierra Tintop
 Posted: Fri Jul 19, 2019 9:09 pm |
I have rebuilt mine just recently. It was actually incredibly simple. Ill try do a write up in the next couple of days.
Gwagensteve
 Posted: Fri Jul 19, 2019 9:11 pm |
Which wear parts were you able to source replacements for?
outterlimits95
 Posted: Fri Jul 19, 2019 9:21 pm |
Gwagensteve wrote: Which wear parts were you able to source replacements for? Essentially all that's in them is the worm gear, and associated rod/gear, two bearings, and two oil seals. The bearings in mine were absolutely shagged. So replaced both, one was a bit of a pain to get out but the bearing they used has a separate outter race so was fairly easy to press back in without damaging the actual bearing. New seals were easy. Packed with waterproof grease (just in case of water ingress when off road). Made a new gasket. Bolted it all back together. Including painting, blasting, and ordering the parts it took me a day too do. If I had everything there ready to go (without having to wait for paint to dry) it's about an hour's job. When I do the write up this weekend, I'll including photos and part numbers (if I still have them).
Gwagensteve
 Posted: Fri Jul 19, 2019 10:57 pm |
Did you achieve factory preload once rebuilt?
outterlimits95
 Posted: Sat Jul 20, 2019 7:58 am |
Not sure yet, i havent put it in the car or done any testing, but i'll keep you posted.
Gwagensteve
 Posted: Sat Jul 20, 2019 8:56 am |
The worm gear and associated rod/gear are the parts that wear.
It's much easier to check preload on the bench than in the car.
Did the steering box have play before you pulled it apart or was it just leaking?
