[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
zook ute
Vehicle: suzuki ute
 Posted: Sat Aug 10, 2019 9:42 am |
I recently bought an GTI engine /5 speed trans, loom etc to do a conversion on my Sierra, what clutch is everyone using as I want to replace it before fitting, is it a standard Sierra 5 speed clutch or a combination of Sierra and GTI,Also what airbox set up, it has a pod filter but I'm not keen on using that, it also needs a new dist cap, I read somewhere that a Barina one is used, does anyone have a part no, the other problem is a broken vacuum valve on the inlet manifold (see pic ) any idea what it is called so I can organise another, first pic is the zook it will be getting fitted to.
303zuke
 Posted: Sat Aug 10, 2019 5:28 pm |
zook ute wrote: The other problem is a broken vacuum valve on the inlet manifold (see pic ) any idea what it is called so I can organise another, ........ Vacuum Switching Valve Assembly (VSV): 18117-64B50There should be two black rubber vacuum lines going to this valve, do you have the other one? Dizzy cap and rotor usually used is Mazda 323: viewtopic.php?f=5&t=55129
zook ute
Vehicle: suzuki ute
 Posted: Sat Aug 10, 2019 10:45 pm |
Thanks for the help 303, yes the other line is there, thanks for the link on the cap/rotor.
ZUZUKI
Joined: Thu Sep 02, 2010 5:50 am Posts: 427 Location: Melbourne
 Posted: Sun Aug 11, 2019 12:56 am |
Well purchased - a lot of work has gone into that car. Very good start on getting a beasty back on the road. Good luck with it. Rgs, Michael
zook ute
Vehicle: suzuki ute
 Posted: Sun Aug 11, 2019 10:24 am |
Thanks ZUZUKI, the car is a bit different than it looks in the pic (the pic is from 10 years ago) can't wait to get it done but it's going to take awhile.
kubes222
Vehicle: Twin cam Sierra
 Posted: Mon Aug 12, 2019 10:00 am |
zook ute
Vehicle: suzuki ute
 Posted: Mon Aug 12, 2019 2:16 pm |
Thanks for the link, lots of good info in there.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 338 guests
