Hi guys, this has occurred over time where when I start my car the rpm is at 1500 until it warms up, then the idle increases to just a tad over 2000rpm when the motor has warmed up, through doing some research I found it may be an issue with the 'Idle Control Valve' not working properly, does this sound right? what other things could cause this? also, where can I find the 'Idle Control Valve' within the efi system? thanks in advance
Users browsing this forum: No registered users and 311 guests
