It is currently Mon Oct 19, 2026 1:57 am
Vehicle: 2013 Jimny Sierra
Post Posted: Wed Aug 04, 2021 8:08 am
Hi all,
My Jimny has been getting less and less happy over about a 12month period, starting with installing a snorkel.
I had an issue three weeks ago with a check engine light, and running on 3 cylinders. Mechanic put new leads, plugs and coil pack in and it runs again with no light. The code at the time was P0134 O2 sensor no activity, so it has a new O2 sensor in it now too.
But I'm still having issues with cold starts. Car runs great once it's going, but won't start on My attempt except the first kick. Sometimes I can get it to start by pumping the throttle.
If it does, it's super rough for about 60 sec, revs around 200-300 before gradually picking up.
Anyone like to chip in on what to I try first? I'm sick of taking it to the mechanic and forking out cash for no results. I live in regional QLD and there's no decent mechanic for 2.5 hours.
Sent from my Pixel 4a using Tapatalk
Post Posted: Wed Aug 04, 2021 7:09 pm
Compression test? Is it low on power?
Post Posted: Thu Aug 05, 2021 6:09 pm
hang on a minute, it threw a code for no O2 sensor activity and the mechanic put plugs, leads and a coil pack in it?
Was it a suzuki genuine coil pack? I believe aftermarket coil packs are garbage.
pumping the throttle won't make any difference to an EFI car. The start map is predetermined.
If its not throwing any codes at all, first cab off the rank would be fuel pressure.
Post Posted: Thu Aug 05, 2021 6:27 pm
Yeah aftermarket coilpacks are always junk compared to genuine, but genuine cost $$$.
I agree with steve re: checking fuel pressure.
A fuel pump dying a slow death will do strange things and in my g series jimny threw a myriad of oddball codes.
Post Posted: Tue Aug 10, 2021 7:18 am
Is a fuel pump relatively cheap? I can hear it running before start, and the car runs fine once it's going...
Post Posted: Tue Aug 10, 2021 7:19 am
I'm planning to have a look under the cover tomorrow to see if I can tell. Will let you know.
Post Posted: Tue Aug 17, 2021 7:19 am
So, here's the update.
  • I pulled the ignition leads off and checked all the plugs, and measured the gaps were correct.
  • Definitely not original Suzuki leads - aftermarket ones have been put in.
  • One of the bores for the plugs had about 5cm of rusty water in it, which I blew out with an air compressor, then cleaned everything with electrical spray. I re-assembled everything (no other issues noted) and started the car.
  • Problem is now much worse, seems like we're on the right track. Hard to start, and sounds like it's running on fewer than four cylinders. There's an unburnt fuel smell as well.
  • Car is currently sitting in the garage waiting for an auto electrician to check the leads and wiring harness.
Photos:
https://imgur.com/a/niqojK5
Post Posted: Sun Sep 12, 2021 9:17 am
Just in case anyone's reading this in the future.
I found myself a copy of the service manual for my car and read the chapter on ignition. The "much worse" bit turned out to be my fault, I didn't put the leads back the right way. I grabbed a multimeter and tested the leads and coil packs. Coil packs came up fine, but the leads were way off spec. I replaced them with a new set of OEX leads that actually exceeded spec and now she's running beautifully again. Still a bit fussy starting sometimes, but I think I'll just have to wait until something breaks to find out the reason now.
Post Posted: Sun Oct 31, 2021 9:35 pm
Update:
Jimny was still less than perfect. I decided to test and replace IAC valve. Tested following procedure in service manual, definitely faulty, but is it causing the issue? Replaced with new IAC valve from ebay, seems to be back to her old self again, idle is rock steady and starting nicely again.
Thinking of doing a full write up since I couldn't find any decent info on the procedure, I took lots of photos. Do you think that'd be worthwhile?
Post Posted: Mon Nov 01, 2021 10:24 am
Always worthwhile
Users browsing this forum: No registered users and 419 guests
