It is currently Sun Oct 18, 2026 2:50 pm
Vehicle: 09 Jimny Sierra
Post Posted: Mon Oct 03, 2022 4:04 pm
Picked up a NGV Saturday with the 2.7, Changed the oil today as the kld was dirty as and replaced with 10w40 shell, Now when I use the throttle I hear a rattle on decel. it does have a bung coil atm but when it was missfiring before the oil change I never heard the rattle.
Wolf jimny- made from 50% recycled goods
Post Posted: Wed Oct 05, 2022 3:17 pm
timing chain replacement
Post Posted: Wed Oct 05, 2022 4:13 pm
100% agree with tanshi. Timing chain
Post Posted: Thu Oct 06, 2022 5:11 pm
would an oil change make it appear?
Post Posted: Fri Oct 07, 2022 12:15 am
It can, depending on the oil & filter you use - the chains have hydraulic tensioners, too thick an oil and you won't get the flow you need (and consequently the pressure) at the tensioner, so it rattles, use a filter without an anti-drain-back valve and the oil drains back when the engine is off, same result.
Post Posted: Fri Oct 07, 2022 8:48 am
I got my partner to rev the car last night and I had a listen around thr car. Sound wasent premenant in the engine bay and wasent loud at all when I had my ear to the engine. sounded like it was comming from around the transmission area. maybe loose heatsheild
Post Posted: Fri Oct 07, 2022 10:14 am
Or a disintegrating catalytic converter.
Post Posted: Fri Oct 07, 2022 1:08 pm
Seeing as it thew 0420 and 0430 and was missfiring may well be. ill try ask around if anyone has a scope i know to have a look down the o2 sensor hole
Users browsing this forum: No registered users and 212 guests
