It is currently Sun Oct 18, 2026 12:51 pm
Vehicle: 1984 sj40
Post Posted: Tue Nov 22, 2022 11:20 am
Having ignition trouble, ideas and input welcomed
SJ410
Not getting spark at the spark plug ❌
Have checked fuses and that power goes to ignition coil and distributor cap. They do✅
I did a test to prove ignition coil works by plugging spark plug lead directly into ignition coil and wrapped some cable around ig coil negative and arced the other end of the cable to motor frame this showed the spark plug arcing. ✅
I have replaced the points in the distributor cap, set the contact gap with a thin piece of paper and cleaned the distributor cap, new spark plug leads have been ordered but I don’t think there the issue.
Fuel gets to carby no problems also.
Any help appreciated
Vehicle: 96 Coily Ragtop
Post Posted: Tue Dec 06, 2022 11:28 pm
Follow the 12v leads from the Coil and check connections
That was my issue
Post Posted: Tue Dec 06, 2022 11:40 pm
If you're getting a spark from the coil but not to the plug, the problem HAS to be between the coil & the plug - in other words - distributor cap, rotor or leads - the spark is there but not getting from the source (the coil) to the destination (the plugs)
And please, feeler gauges aren't expensive, set the contact breaker gap correctly.
Post Posted: Wed Dec 14, 2022 7:49 pm
All well and good whilst the engine's not vibrating the shit out of everything
Users browsing this forum: Google [Bot] and 204 guests
