It is currently Sun Oct 18, 2026 12:13 pm
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Mon Apr 28, 2025 1:49 pm
Guys...
I've removed the diff centre from my son's '96 LWB WT Sierra (Murati(?) with a 1.6ltr Engine Conversion) and taken it down to the Diff Shop to inspect. The result is not good, and the R&P is not usable. So, we are looking for another either 4.1 R&P or another 4.1 Diff Centre. Does anyone know of someone who may have one or where to source one from. (Brisbane Area - northside)?
The Guy down at the Diff Shop did mention that he "thought" that the early Jimny Diffs might be suitable - either just the R&P &/or the complete centre. Does anyone know if this is correct? From the research I've done the early Jimny's appear to have a 4.1 diff ratio so it would be nice if the centres were interchangeable... or at least the R&P if not the centre housing...
Also, it seems the previous owner got carried away when they replaced the rear wheel bearings and has ground into the axle itself. Would like to source some good 2nd hand ones or I've noticed that on eBay you can source new ones from India but I'm a bit concerned buying anything from there as to the correct part &/or quality of the parts... It's the only place where I have seen new axles for sale and I assume they are WT and not NT ones...
thanks in advance
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Mon Apr 28, 2025 4:58 pm
Maruti 4.11, jimny is 4.09
Post Posted: Mon Apr 28, 2025 6:32 pm
Thanks for that... I was looking on the 4wdpartshop.com.au page and they indicated/listed the early Jimny's having a 4.11 (see: Rear Crown Wheel / Pinon Gear Set 4.1 Ratio
May be they have the incorrect parts data for the early Jimny's ??
Post Posted: Tue Apr 29, 2025 10:00 am
I could be wrong, I'm sure someone will chime in soon enough :)
Post Posted: Tue Apr 29, 2025 12:17 pm
No, think you're right after further research... they funny thing is the difference between the 2 ratios is only .5%, so considering the front diff should be engaged offroad, then how much of a difference would the .5% make?
BTW: Another option I'm looking is at sourcing some 2x 3.9 Ratios and swap out the Front & rear for the more common 3.9ratios... Does anyone have any 3.9 ratios that they are willing to sell?
Users browsing this forum: No registered users and 298 guests
