| Author |
Message |
burls
Joined: Sun Mar 07, 2010 10:30 pm Posts: 989 Location: Ipswich
Vehicle: 95 sj70 and 78 lj81
 Posted: Fri Jun 13, 2025 5:23 pm |
For those that have done it, what do l need to grab from the donar cappuccino
DesmondTheDrover
Vehicle: 1985 Holden Drover 1.3litre
 Posted: Sat Jun 14, 2025 8:34 pm |
What are you swapping into?
burls
 Posted: Sun Jun 15, 2025 4:58 pm |
BlueSuzy
 Posted: Mon Jun 16, 2025 5:28 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Tue Jun 17, 2025 8:55 am |
I’ve done two f6a swaps but into an SJ70 and SJ40. Lj50 is going to make things much more complex. The cappuccino gearbox has a huge shift extension on the back that’s not easily managed and will be a big problem for an LJ.
VSS will be harder with an LJ cluster.
A custom gearbox mount will be required as the LJ doesn’t have a mount down the back.
I haven’t seen a 50 f6a swapped but I’ve seen 80’s where there is more room for the motor.
It’s going to be a challenge to keep the 50 bonnet.
burls
 Posted: Tue Jun 17, 2025 6:51 pm |
Thanks Steve, looks like the F6A that l had lined up has fallin through. Ok back to your comments. . The huge shift thing - can that be removed and put a top loader like you can on a vitara box? Custom mounts is my middle name as l had to with the LJ81 build l did so no fab issues there Bonnet wise l will be using an80 bonnet which l know will be tight just like the G16 was.
I am also looking at a K10C which l believe would work but need to make a bell housing adapter also doable. Thoughts?
Gwagensteve
 Posted: Wed Jun 18, 2025 7:42 am |
I think the k10c is enormously tall as it was designed for the wagon R which had a very tall cowl. Inlet manifold is plastic and sits up super high
No we found no solution for the shifter. We shortened it but it didn’t work properly and a kei sierra gearbox was sourced.
burls
 Posted: Thu Jun 19, 2025 5:14 pm |
Again thanks Steve
More spit balling daewoo matiz? Maybe? Also l’ve just been looking at the cap manual. I can get my head around the gearbox linkage. Do you have any photos of one at all
burls
 Posted: Mon Dec 08, 2025 1:01 pm |
Little update, I’ve managed to Aquire what appears to be a late model F6A (with EFI). The gearbox that came with it is and AWD from an Alto which won’t be used. 1. Now can l find what vehicle it was actually from. 2. What gearbox could l fit? 3. Is there anywhere in Aus to get engine rebuild kits and parts?
Gwagensteve
 Posted: Tue Dec 09, 2025 8:51 am |
All F6a’s are EFI as far as I know. Odds are it’s from an Alto? You’ll need a gearbox from a 660cc Sierra. (The last 660cc sierras were K6a, unsure if the bellhousing bolt pattern is the same. The bolt pattern does not match the F8A/F10A.
Parts are not readily available locally.
burls
 Posted: Thu Dec 11, 2025 12:29 pm |
Thanks Steve, a 660 sierra! Guessing that’s an import operation then?
Gwagensteve
 Posted: Thu Dec 11, 2025 3:24 pm |
Correct. There are a few around. Many are F5a but I think the bellhousing pattern is shared.
UBZ
Joined: Sun Nov 16, 2008 10:30 pm Posts: 301 Location: NZ
Vehicle: LJ50 , LJ80Q-II
 Posted: Mon Dec 15, 2025 11:45 am |
Gwagensteve
 Posted: Mon Dec 15, 2025 2:11 pm |
burls
 Posted: Tue Dec 16, 2025 12:27 pm |
Drive shaft is flogged out, would it fit in mu suitcase?
Gwagensteve
 Posted: Tue Dec 16, 2025 12:46 pm |
You’ll want a large suitcase.
A large duffel bag would be better.
Gwagensteve
 Posted: Tue Dec 16, 2025 12:47 pm |
I think the output shaft spline is the same as 1.0 litre from memory. Jackshaft is very close to 1.0 litre
