It is currently Sun Oct 18, 2026 11:54 am
Post Posted: Wed Dec 20, 2006 2:18 pm
My diff in my sierra has been a little noisy for a little while now, but this morning when i was driving it i noticed a bad clunking/banging noise every time i braked. It isn't there when I accelerate or back off, only when I brake, and now there is diff oil coming out on the LHS rear axle.
Any idea's on what it could be? I'm about to go strip it and investigate
'85 Sierra SWB with Fibreglass hard top
30 inch M
Post Posted: Wed Dec 20, 2006 2:20 pm
blown wheel bearing
almost lay money on it, lucky there wasnt a fire, ey steve :)
Post Posted: Wed Dec 20, 2006 2:51 pm
Thats what I had in mine, and i reckon it's leaking from the wheel seal?
So that'd explain it only clunking under brakes?
30 inch M
Post Posted: Wed Dec 20, 2006 2:54 pm
yeah the axle drops down and the seal cant seal, then when you hit the brakes the shoes clunk and it centres the axle again
Post Posted: Wed Dec 20, 2006 4:31 pm
Just waiting on a slide hammer now so I can get the axle out. Would the diff problem of caused this do you think? (Not enough pre load on the pinion)
30 inch M
Vehicle: 75 Cruiser
Post Posted: Wed Dec 20, 2006 4:51 pm
is the axle stuck in there?
I use a metre long chain for this, the two ends can be slid over the axle studs, put the two nuts on, then first yank on the chain and it usually comes out, or if it's really stuck get a pick handle, slide it through the chain loop and yank that.
or you could use a slide hammer if you have one :lol:
Post Posted: Wed Dec 20, 2006 4:57 pm
Was gunna get a slide hammer from work but will play around with your idea later, cheers.
30 inch M
Post Posted: Wed Dec 20, 2006 5:15 pm
put the drum on backwards and put the nuts on a few turns, instant slide hammer
Post Posted: Wed Dec 20, 2006 6:52 pm
Tried that, it's fkn tight. Last time I had them out I had to use a slide hammer
30 inch M
Post Posted: Wed Dec 20, 2006 7:20 pm
botl drum on like normal
then do the same with wheel and tire
Post Posted: Mon Jan 08, 2007 12:45 am
supercheap auto. $20 dent puller. i didnt even need to make an adapter.
just used the hook that came with the kit. came off easy.
tried the reverse drum thing but it wouldnt move.
Users browsing this forum: No registered users and 297 guests
