It is currently Sat Oct 24, 2026 4:54 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Post Posted: Thu Mar 18, 2010 7:11 pm
so joe, to side track a little, a jimny airlocker couldnt be made to work in a non highpinion i.e 1 litre diff?
Post Posted: Thu Mar 18, 2010 7:20 pm
If ARB's parts catalogue is correct, then no :(
The parts catalogue for ARB air-lockers lists a Jimny front crown wheel bolt diameter (130mm) and the ID of the crown wheel (108mm) as the same as a RD88 (Sierra rear end). If this is true, a Jimny front diff is not a 1L size at all, but is in fact a high pinion 1.3 size. This makes sense, considering I have heard of people claiming they have modified Jimny front air lockers to work in a coily, and people in this thread have said coily front diffs are simply high pinion 1.3 size.
BlueSuzyi wrote:
Front of Jimnys diffs are 1L sierra size.
Would you care to verify?
Clearance Hole Technology :P
Post Posted: Thu Mar 18, 2010 7:52 pm
ok...lets get a few things straight.
the jimny ring gear may be the same ID as a 1.3, and may have the same bolt pattern, but this does not mean its OD and pinion are the same as 1.3, for which they are NOT.
the carrier (cast section) of the jimny IS 1.0 litre size in its diameter and bolt spacing, the 1.3 is much larger and the same as a coily. you can modyfy a sierra front locker as well as a jimny front to suit a coily, but this involves some horrible things to do to an airlocker.
Post Posted: Thu Mar 18, 2010 8:08 pm
OK. So its not truely a 1.3 or 1.0L size at all. Some sort of semi-hybrid thats high-pinion to boot. It should just be called a unique diff type then.
Thanks for the clarification :)
I think there is allot more to discuss here, but I don't really see the point anymore...
Post Posted: Thu Mar 18, 2010 9:49 pm
If your just going to be running 30's max. I wouldnt bother changing the ratios. It is going to cause a major headache. :lol:
hahaha, its looking to be the case currently :D im interested by jap tranny gears. but im gunna assume this would be a couple of k to get bought in yeah... maybe sluggy wheelin, or smaller tyres may be on the cards for this broke young man :|
might just be the slowest build on the forum...
Users browsing this forum: No registered users and 110 guests
