It is currently Sat Oct 31, 2026 11:56 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Fri Sep 17, 2010 11:00 am
joeblow wrote:
so the legendary air locker has plastic internal parts, bit of a disappointment 8O
if it were a steel piston it would be a heap less forgiving. the plastic one actually puts up better with shock loading to a point.
been doing some more digging........seems the piston will do that when engaging the diff with one wheel spinning......or 'crash locking' them going around corners.
that's fair enough, but i've never engaged it with a wheel spinning or trying to lock it going around corners.
as i said earlier i've got mechanical sympathy for my 4wd. the plastic looks to be pretty flimsy & it snapped the 4 tabs off one end (not sure what they looked like) & the same end has a crack in the ring, will post up pics in the morning.
Post Posted: Fri Sep 17, 2010 11:02 am
You cant argue airlockers with a Company man, they will swear they have never seen that happen before, even when 20 people can line up with teh same problem *cough* Patrol Fronts *cough* :)
Post Posted: Fri Sep 17, 2010 11:07 am
wrong royce.......i have seen it before. even when i had the shop. was the piston sent off for a claim?
Post Posted: Fri Sep 17, 2010 11:10 am
no warranty offered & a bill for $220? the locker was JUST out of warranty... i have the piston sitting on my passenger seat. :twisted:
Post Posted: Fri Sep 17, 2010 11:11 am
nope, while searching for parts TJM said here have 2 pro lockers, see how it goes :)
I believe the parts were got eventually, once they start to slip the shavings were compounding the problem
Post Posted: Fri Sep 17, 2010 11:21 am
no....i meant did atari send off the bits.........not you. is that what the store said?....or did they contact head office?
Post Posted: Fri Sep 17, 2010 11:25 am
i think it was just what the local shop said, they did have it for over a month so it could have been back to head office.
all that i know is it's been fixed but for how long?
the plastic seems to be pretty average quality & it still had the dags left on it from casting/moulding.
Post Posted: Fri Sep 17, 2010 11:38 am
number 8 in this diagram is what failed & it was the little tabs on the RH end that went to lunch with out the rest of part number 8 :lol:
Post Posted: Fri Sep 17, 2010 10:17 pm
:P You could nearly make one out af a Gv diff... :lol: :lol: 8O
Post Posted: Thu Sep 23, 2010 1:21 pm
so i've finally uploaded the pics i took the other day....
this shows the tabs that have broken off & you can see all the dags of plastic left over from when it's come out of the mold.
this one shows the crack in it...
i can't believe the arb locker has farken plastic in it 8O
Post Posted: Thu Sep 23, 2010 8:18 pm
:roll: Your just a rough prick Gus.. :lol:
Post Posted: Thu Sep 23, 2010 9:03 pm
no plastic in a lockright
:thefinger:
Vehicle: SJ80, SE416
Post Posted: Fri Sep 24, 2010 4:36 am
Hey Joe,
I have a friend who has had this happen to the pistons in both his lockers. He was told the next generation of ARB lockers have/will have a piston-less design. Do you know if this is true?
Also, is this part plastic in order for it to be a 'weak point' to protect other parts of the assembly?
Users browsing this forum: No registered users and 279 guests
