It is currently Wed Oct 28, 2026 2:22 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
Post Posted: Tue Jun 22, 2010 1:25 am
mightymouse wrote:
I bloody good idea I just recently saw was a industrial rubber glove with the tips of the fingers cut and pulled down over the distributor and the leed pulled through the fingers It was apparently very succesful. The end that is usuallt up the wrist was zip tied around the distributor base.
Much like the datto in this thread. Works well until the glove perishes.
http://auszookers.com/index.php?name=Fo ... pic&t=3674
Post Posted: Tue Jun 22, 2010 2:31 am
use inox, wd40 and so on conducts electricity :wink:
permatex make a grease you can use to seal plug boots with, vaseline also conducts electricity and will melt before you get up to operating temp
though its probably better to find and fix the problem, shouldnt be happening even when almost swamped, its not like all the ignition stuff isnt higher than the intake :)
Vehicle: 4wd
Post Posted: Tue Jun 22, 2010 2:44 am
Zookin_85 wrote:
you mean if it cant be fixed with WD you need a hammer and if that dont work get a bigger hammer??? :lol:
Thats the way. Give your dizzy cap a belt with a hammer and see if that helps.
I had a coily that hated water. Evertime I went through a water hole it would play up for the next week. Tried everything and could never work out what it was.
Nowadays I just avoid water where I can.
Watch out or you'll get sued.
Users browsing this forum: Google [Bot] and 371 guests
