It is currently Wed Oct 28, 2026 2:28 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
Post Posted: Fri Jul 30, 2010 3:50 pm
polar_bear is running the same set up in his vitara with a solid bar that's been drilled & tapped to take a couple extra mounts on his winch bar.
my bar aint solid.. its just a bit of scaffold tube with some big arse washers and nuts welded to the end of it 8)
Go Hard, Trailer Home
Post Posted: Fri Jul 30, 2010 10:48 pm
why not just put a solid bar the whole way thru that tube on the sierra's like what shep did to fit his toobe bar.
I think it was 32nb pipe, not oslid tube on sheps.
I did that to the rear crossmember on mine.
Welded 100x100x6mm plates on the rear cross member and extra pipe to bolt my rear bar up to. While still using the factory rear bar bolt holes.
Users browsing this forum: No registered users and 339 guests
